Audio files: 728
Posted: Sun May 10, 2015 5:20 pm Post subject:
PHOBoS - All Systems Drifting Normal Subject description: droney synths and fieldrecordings
I patched something up and I thought it sounded nice so I recorded a part of it. However because it was already running
when I started recording it didn't really have an intro. So I took the end, cut it up a bit and used that at the beginning.
And while I was at it I added a couple of fieldrecordings to it as well.
PHOBoS - All Systems Drifting Normal.mp3
Filesize:
13.63 MB
Viewed:
3547 Time(s)
Cover Art
Filesize:
1.22 MB
Viewed:
862 Time(s)
Audio files: 728
Posted: Fri May 15, 2015 9:48 am Post subject:
Thanks! varice, AlanP and Steveg (did this get linked somewhere else ?!)
It was actually a pretty simple patch. It started with the Bay-B-Key, which the last time I tried it decided not to work anymore .
It just played the demo and than stopped and didn't respond, like the demo button was stuck but there isn't even one attached.
So I thought I'd give it another try, you never know, right ?! and it worked again! So I had a nice sequence going on that one.
Than I added some notes from the EK2100 which has a simple build in programmable sequencer and it stepped to those notes
at random. And my other DIY synths for a low bass sound and another drone/tone that fades in and out. All mixed with some
bleeps and blips from the Moon Base Xplorer. oh and there are some woodblock + clave sounds aswell.
