Coming up on Radio 1 at
Complex Noise Generator Experiments
Page 1 of 2 [41 Posts]
PostPosted: Sat Feb 27, 2010 4:24 am    Post subject: Complex Noise Generator Experiments
Subject description: New samples to check out
I've been playing around with an idea for a complex noise generator.
Maybe I should define what I mean by "complex noise generator" first.
What I want is something which is untuned, contains many frequencies, repeats at regular intervals (which can be controlled)(maybe even triggered) and could be patched in as an alternative noise source.
It could be used as the noise in a snare drum, in a way which makes the snare sound different every time it's hit for example.
Gated into short bursts, it would be a great glitch generator.
Anyway,
I've gotten it to this point, which I present here as a sample .mp3
Is it too obvious what is creating this sound?
I'll let you know soon, I just want to hear what people think it is first! Very Happy
ComplexNoise1.mp3
 Filesize:  376.06 KB
 Viewed:  2509 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Sat Feb 27, 2010 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Unc,
I'm thinking TH's voltage controlled noise source driven by Ian's chaos CV or maybe just even a red noise source. Kind of a dual noise circuit, I suppose.
Synth DIY since 1977!
Inventor
Audio files: 270
PostPosted: Sat Feb 27, 2010 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds like a demonic spirit trapped in a washing machine. Is that it?
Les
dragonfrog
PostPosted: Sat Feb 27, 2010 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are a number of bits in there that sound like vowel sounds - is it some kind of sampled speech box toy, like a speak&spell?
DGTom
PostPosted: Sat Feb 27, 2010 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
No idea what it is, but I like it!
There is a real vocal quality tho, without the preface I would've assumed it involved a cheap mic, lo-fi sampling & lots of gain Cool
PostPosted: Sun Feb 28, 2010 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Well you all came very close.
It is, in fact, two talking birthday cards, sent through an arse about Ring Modulator built with two audio transformers and some germanium diodes.
In the left corner we have someone pretending to be David Beckham, and in the right corner we have a Marlin Brando sound alike. (just wait till I unleash Bogey on you! Wink )
The circuits I found in these cards ($4 each on sale) have SMD pitch set resistors which I have replaced with a 500K pot. They are triggered by a little 555 astable so I can control how often they reset to the start. (I'm hoping to include a 10V trigger to force the 555s to discharge, anyone know how to do that?)
They also used tiny 8R speakers. That made me think about using 8R -> 1K CT matching transformers for the ring mod, in a back to back arrangment. The diodes ring around the primary windings, and the output is taken straight off the centre taps. Ken's RM schem shows the carrier going in where I took the output off. I'm not sure what difference this has made, but matching the 8R secondaries to the 8R outputs of the cards was just too neat to pass up.
So at this stage the whole thing has cost about $20.
It's about to get a whole lot more unholy though.
I'm going to clone what I already have using Bogart and Bruno, then I'm going to send the outputs of each of these montrosities into a third RM using the classic 3K->3K CT arrangement of Ken's schematic. Twisted Evil
Inventor
Audio files: 270
PostPosted: Sun Feb 28, 2010 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy, will the 555's reset pin do the job for you? You can drive it with an inverter if need be.
Les
PostPosted: Sun Feb 28, 2010 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Les
Yeah, it probably would Les, but the astable setup I've done already uses the reset, and I'm not sure how to add on to it without upsetting what's there already.
Inventor
Audio files: 270
PostPosted: Sun Feb 28, 2010 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you post a schematic Andy? Ideas include using a transistor to discharge the timing capacitor and using resistors to feed in multiple signals to the reset.
Les
Audio files: 353
PostPosted: Sun Feb 28, 2010 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Noise sweet noise!
parasat
PostPosted: Sun Feb 28, 2010 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you need one of Ken Stone's Super Psycho LFO (in audio range) or a Cacophonator:
http://electro-music.com/forum/topic-14440.html
droffset
PostPosted: Sun Feb 28, 2010 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wild stuff Uncle K, I like it.
Edit: Spelling mistakes.
j.dilisio
PostPosted: Sun Feb 28, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool,. i want to hear these snares Very Happy
DRONEGOAT
PostPosted: Thu Mar 04, 2010 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the basic schem at this stage.
Let me know if anything looks amiss.
How do we short that cap Les?
 Filesize:  19.78 KB
 Viewed:  922 Time(s)
Lorenzo
PostPosted: Sun Mar 07, 2010 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
oooh very interesting!!
I like very much your 555 trigger... I think I will try to use it for my 4 chicken that say "merry xmas" .. but this is a Circuit Bending OT
Yes!
Oh Yeah!
Wow!
Inventor
Audio files: 270
PostPosted: Sun Mar 07, 2010 10:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy,
The datasheet that I looked up here (I'm at my bro's house and have no access to my hoard of goodies on my Mac mini) says that the output can drive 200mA without buffering. So you probably don't need that 2N3904 buffer transistor or it's base resistor. So that might clean things up a bit if I'm not mistaken.
Next up, the schematic shows that reset is tied high to Vcc. That's OK for normal use but you wanted a reset, so I'd hook that input up to a pull-down SPST switch with perhaps a resistor in series. Pull it up with a weaker resistor and you'll be golden.
Please correct me if I'm wrong or ask questions if I have not been clear enough.
Les
LMC555.pdf
The LMC555 datasheet for your convenience
 Filename:  LMC555.pdf
 Filesize:  767.09 KB
 Downloaded:  678 Time(s)
PostPosted: Mon Mar 08, 2010 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Les, the problem is that I want it to run as an astable unless it recieves a trigger which I'd like to force a reset of the timing by discharging the cap.
Inventor
Audio files: 270
PostPosted: Mon Mar 08, 2010 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy, when -reset gets a negative pulse, it drives a high value into the gate of the discharge transistor which will accomplish your goal. So you want a signal that is normally high and goes low briefly to discharge the cap, and apply that to reset. If your pulse is normally low with a positive level for the discharge trigger, then just use a common emitter NPN stage to invert the pulse.
555's are fun, I like them!
Les
PostPosted: Mon Mar 08, 2010 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Les, I think I'd need to see a schem to get what you mean. Do I have the reset only connected to the trigger input?
BTW, I agree that I probably don't need the NPN buffer. I just had it there while I was testing the running of two boards off the same 555. They draw about 100mA each. (Although I don't know how they got 100mA out of 3 button cells!?! Laughing )
Inventor
Audio files: 270
PostPosted: Mon Mar 08, 2010 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Andy, just connect the reset inputs to the trigger signal. This should accomplish your goal if the trigger signal is normally high and goes low for the trigger. If it's the other way around, just invert the trigger with a hex inverter or a transistor switch. Hope that helps.
Les
PostPosted: Tue Mar 09, 2010 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I've decided I'll use a switched trigger socket for each which will leave them in astable unless the trigger is plugged in. More intuitive and saves on panel components.
PostPosted: Tue Apr 27, 2010 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, here are a couple of samples of what I've got so far.
All four modules are in the panel with their own 555 trigger.
They share a power supply which is built on one board.
This is great, cos they are bleeding into each others module sound.
The 555 clocks are also stealing from each other, which is really good too!
This is turning out heaps better than I thought.
There is no ring-modulation happening yet. These samples contain just the raw outputs of the sample modules.
Each module has a control for it's on time, off time, and pitch.
First, just a "patch" I set up with all four voices.
RingNoise270410.mp3
 Filesize:  291.84 KB
 Viewed:  2320 Time(s)
PostPosted: Tue Apr 27, 2010 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
This one is a lot longer.
It's me "playing" the unit.
The great thing is that even with the ring-mod added, I will still have access to these individual voices if I plug into all four of them. Very Happy
RingNoise270410b.mp3
 Filesize:  3.94 MB
 Viewed:  2289 Time(s)
PostPosted: Wed Apr 28, 2010 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Here, I tried to get all four voices to play the same note. It's very hard, which is good for what is intended to be a noise source.
RingNoise280410.mp3
 Filesize:  810.2 KB
 Viewed:  2243 Time(s)
Lorenzo
PostPosted: Fri May 21, 2010 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
WOW!!!
Yes!
Oh Yeah!
Wow!
