Multi Drum Patch
Page 1 of 1 [2 Posts]
pauldirks
PostPosted: Sat Jan 28, 2006 8:08 am    Post subject: Multi Drum Patch Reply with quote  Mark this post and the followings unread
OK- I'm a newbie- and I'm not sure what I'm doing wrong. I want to set up a patch to have 3 drum sounds: kick, snare and hihat. I want to be able to use it via cubase and to have each sound respond only to one midi note. For experimentation I grabbed a drum patch from the archives and connected a kbd module- and it sounds no problem if I connect the gate out of the kbd to gate in on the drum sound. But if I connect the gate out on the midi recv module i get nothing.What am I doing wrong?
Much thanks,
Paul
drum trial.pch2
 Filename:  drum trial.pch2
 Filesize:  1.32 KB
 Downloaded:  1245 Time(s)
Audio files: 266
PostPosted: Sat Jan 28, 2006 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it is working. Since you are using the MIDI Note Receive module, the gate only detects note C4 on Channel 1, but it works.
