Coming up on Radio 1 at
Need help with this Chuck program
Page 1 of 1 [3 Posts]
JeEA
PostPosted: Fri Apr 21, 2017 8:46 am    Post subject: Need help with this Chuck program Reply with quote  Mark this post and the followings unread
How does this program work?
I am using a usb hub and 2 waldorf rockets.
I know it is for 4 units, but i have made a prg for 2 units
My problem is that nothing happens. I don't know what is wrong.
// call setupOut(midi device, midi channel, true enables CC messages input)
// for all devices that receive MIDI data. Run chuck --probe to find device IDs
Rocket rockets[4];
rockets[0].setupOut(3, 1, false); // Rocket #1
rockets[1].setupOut(4, 2, true); // Rocket #2
rockets[2].setupOut(5, 3, true); // Rocket #3
rockets[3].setupOut(6, 4, true); // Rocket #4
// call setupIn(midi device, midi channel)
// for all device that send MIDI data. If you include a device that you also
// ran setupOut for here, and it sends MIDI CC data, you must set the third
// argument for it above to false.
Master master1;
master1.setupIn(3, 1); // Rocket #1
Master master2;
master2.setupIn(2, 0); // Keyboard
class Rocket {
MidiOut midiOut;
int midiDevice;
int midiChannel;
int acceptMidiCC;
-1 => int noteOn;
MidiMsg midiMsg;
fun void setupOut(int device, int channel, int acceptCC) {
device => midiDevice;
channel => midiChannel;
acceptCC => acceptMidiCC;
if (midiOut.open(device)) {
<<< "Opened MIDI output ", midiOut.name() >>>;
} else {
<<< "Couldn't open MIDI output #", device, " Sad" >>>;
fun int sendMidi(int data1, int data2, int data3, int force) {
0 => int sendIt;
// <<< "Got msg ", data1, data2, data3, " state=", noteOn, force, sendIt >>>;
if (isNoteOn(data1, data3)) {
if (noteOn == -1 || force) {
if (noteOn > -1) {
// Send note off to prevent lingering notes on the Rocket
(data1 & 0xf0) + midiChannel => midiMsg.data1;
0x80 + noteOn => midiMsg.data2;
0 => midiMsg.data3;
midiOut.send(midiMsg);
data2 => noteOn;
1 => sendIt;
} else if (isNoteOff(data1, data3)) {
if (data2 == noteOn) {
-1 => noteOn;
1 => sendIt;
} else if (acceptMidiCC) {
1 => sendIt;
if (sendIt) {
data2 => midiMsg.data2;
data3 => midiMsg.data3;
return true;
} else {
return false;
class Master {
int midiDevice;
int midiChannel;
0 => int nextRocket;
fun void setupIn(int device, int channel) {
spork ~ listener();
fun int rocketIsMe(int rocket) {
return rockets[rocket].midiDevice == midiDevice && rockets[rocket].midiChannel == midiChannel;
fun void findRocketAndSend(int data1, int data2, int data3) {
isNoteOn(data1, data3) || isNoteOff(data1, data3) => int isNoteMessage;
0 => int midiSent;
for (0 => int i; i <rockets> int rocket;
if (!rocketIsMe(rocket) && rockets[rocket].sendMidi(data1, data2, data3, false)) {
1 => midiSent;
if (isNoteMessage) {
if (isNoteOn(data1, data2)) {
(rocket + 1) % rockets.size() => nextRocket;
break;
if (!midiSent && isNoteOn(data1, data3)) {
rockets[nextRocket].sendMidi(data1, data2, data3, true);
(nextRocket + 1) % rockets.size() => nextRocket;
fun void listener() {
MidiIn midiIn;
MidiMsg midiMsg;
if (midiIn.open(midiDevice)) {
<<< "Opened MIDI input ", midiIn.name() >>>;
} else {
<<< "Couldn't open MIDI input #" + midiDevice + " Sad" >>>;
while (true) {
midiIn => now;
while (midiIn.recv(midiMsg)) {
// <<< "Received midi: ", midiMsg.data1, midiMsg.data2, midiMsg.data3, (midiMsg.data1 & 0x0f) >>>;
if ((midiMsg.data1 & 0x0f) == midiChannel) {
findRocketAndSend(midiMsg.data1, midiMsg.data2, midiMsg.data3);
fun int isNoteOn(int noteOnOff, int velocity) {
return (noteOnOff & 0xf0) == 0x90 && velocity > 0;
fun int isNoteOff(int noteOnOff, int velocity) {
return (noteOnOff & 0xf0) == 0x80 || (noteOnOff & 0xf0) == 0x90 && velocity == 0;
while (true) {
1::week => now;
Audio files: 373
PostPosted: Wed Apr 26, 2017 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
Could you please repost your program within code brackets (click the "Code" button when editing your post), and also click "Disable HTML in this post" and "Disable Smilies in this post"? It's difficult to read the code otherwise. Smile
JeEA
PostPosted: Thu Apr 27, 2017 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll give it a try
I do not know anything about Chuck programming.
The program should rute midi input data to 4 different waldorf rockets
synths.
How does the computer know where to send the midi data. They are on a usb hub and the keyboard on a usb - midi interface
Will get back with the program asap
