jutar
Posted: Mon Apr 25, 2016 7:18 pm Post subject:
Help with sort functions - Arrays and logic Subject description: Trying to write using randomly generated sets, stuck on the logic |
I'm working on a project using ChucK to generate random sets. The end goal is to use those sets to play a fugue-style piece, with each successive variation and response as a manipulation of the set. I got ChucK to shuffle my tones, but I'm stuck sorting them into Normal form. Once I get this down, inversions will be easy, though Prime form will be its own headache. Here's what I have so far. I'm hitting two blocks. 1- the swap function overwrites items that shouldn't be in the swap. 2- I get an array out of bounds error when printing the results and I can't find the source. Here's my code so far:
| Code: |
int i,j, dummy, iMin, hold;
[5, 3, 6] @=> int a[];
/* advance the position through the entire array */
/* (could do j < n-1 because single element is also min element) */
for ( 0 => j; j <= a.cap()-1; j++) {
/* assume the min is the first element */
j => iMin;
/* test against elements after j to find the smallest */
for ( j+1 => i; i < a.cap()-1 ; i++) {
if(a[i] < a[iMin]){
i => iMin;
<<< a[i], i, a[iMin], iMin, a[j], j, "pre">>>;
if (iMin != j) {
a[j] => dummy;
a[iMin] => a[j];
<<<a[i], i, a[iMin], iMin, a[j], j, "mid">>>;
dummy => a[iMin];
<<< a[i], i, a[iMin], iMin, a[j], j, "post">>>;
for(int k; k < a.cap(); k++) <<< "Set1[", k,"] = ", a[k] >>>;
| [/code] |
randbits
Joined: Jun 28, 2016 Posts: 6 Location: Utica, NY, USA
Posted: Tue Jun 28, 2016 6:22 pm Post subject:
Fixed Subject description: now the selection sort algorithm |
The right-to-left assignment of values can make things a bit confusing.
The code now sorts in ascending order correctly.
| Code: |
int i,j, dummy, iMin;
[5, 10, 3, 6, 1, 9, 2, 7, 8] @=> int a[];
for ( 0 => j; j < a.cap(); j++) {
/* assume the min is the first item */
j => iMin;
for ( j+1 => i; i < a.cap() ; i++) {
if(a[i] < a[iMin]) {
i => iMin;
a[j] => dummy;
a[iMin] => a[j];
dummy => a[iMin];
This algorithm is very slow. If you feel like taking on a challenge, implement mergeSort instead (https://en.wikipedia.org/wiki/Merge_sort) Wicked fast!
Cheers |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Wed Jun 29, 2016 12:22 pm Post subject:
Why would someone want to sort values like this as part of making a music generating program? If randomly generated numbers are assigned to an array in the order they are generated, it seems to me having an algorithm to sort the numbers into some other non-random order defeats the purpose of having randomly generated numbers in the first place. Just wondering.
Steve |
Former site admin
Audio files: 353
Posted: Thu Jun 30, 2016 2:45 pm Post subject:
The idea to me seems to be to make sets of numbers. To do operations on sets more efficiently it makes sense to sort the elements (although the order of the elements in a set is, by definition, irrelevant).
Anyway, the numbers would still be random, and it would be very easy to extract them again in a random order by randomly indexing the elements.
Sorry for not being able to answer the ChucK question. |
