The SN-Exerciser
Page 1 of 1 [13 Posts]
Thomas_Henry
PostPosted: Wed Jan 07, 2015 12:01 am    Post subject: The SN-Exerciser
Subject description: A Two-Chip, Yet Full-Featured, Noise Box
Hello Gang,
Here's a new project which has turned out to be tremendous fun. It's the SN-Exerciser, a noisemaker box which packs quite a wallop despite needing but two chips.
The SN-Exerciser includes a VCO, LFO, sweepable white noise source, envelope generator (Attack/Sustain/Release), VCA, and a separate clock for repetitive triggering. The VCO offers a 20% duty cycle for reedy sounds, and a 50% duty cycle for fuller bass sounds. Moreover, it can be frequency modulated by the LFO at the flip of a switch.
The VCO operates from 2 Hz to 6000 Hz (a 3000:1 sweep range), while the LFO operates from 0.025 Hz to 130 Hz (a 5000:1 sweep range).
The Attack and Release are variable from 5 mS to 5 S. The repeat mode is variable from 12 bpm (beats per minute) on up to 600 bpm.
The whole shebang runs off of two 9V batteries. Current drain has been kept to a very low +/- 5 mA.
All switches are fully decoded; there are no difficult configurations to memorize. Just flip a switch to engage a feature, and the circuit takes care of the messy details for you. And there's no range-switching; all continuous controls simply require a single pot, and that's that.
The unit may be operated in a locked mode (always on), a triggered mode, a continuously repeating mode or a triggered repeating mode.
The output is line level, with a volume control and stereo output jack for connection to an outboard amplifier and speaker.
The SN-Exerciser is designed around the SN76477 complex noise chip (still readily available on eBay) and the common PIC16F88. Unlike the SN data sheet, however, I have used transistor current sinks to completely jettison the need for range-switching. Thus, instead of a fixed resistor setting basic parameters, variable current sinks control the VCO, LFO, noise clock and noise filter for an extremely broad range of sounds.
The SN76477 even contributes the regulated +5V needed by the PIC. The latter runs at 1 MHz to keep the current drain 50% below spec which is 10 mA max.
The PIC takes care of converting pot values for repetition rate and sustain times to digital by means of its ADC converters. All in all, I believe it will be hard to find a more complete soundmaker which uses so few components.
I posted a simple demo on YouTube:
https://www.youtube.com/watch?v=hNjNtkX1YU4
I designed my own circuit board using FreePCB, and etched the board right in the kitchen. The schematic, and hence netlist, was created with TinyCad, which is also free of charge.
There is one minor kludge to the PCB to be made. On the PCB, pin 16 of IC1 runs to ground. You need to cut that trace, and instead connect it to a voltage divider (12k/1.5k) from +5V to ground. (The schematic shows this update properly). This ensures the pulse width switch really does choose between 20% and 50%. It's an easy alteration to be made; I did it directly on the underside of the PCB.
I used CTS circuit board mounted pots (from Digi-Key), and all of the switches were from Microtivity (ordered via Amazon). The circuit board mounted stereo 3.5mm jack is from All Electronics. All of the other parts are common and junkbox parts should fit the PCB without problem.
Be sure to follow the schematics carefully. There are -9V, +9V and +5V power supply connections. Don't mix them up.
The firmware is written in PIC Micro Pascal. Note that this superior compiler is available completely free of charge, with no limitations, from
http://www.pmpcomp.fr/
I consider PMP to be the most powerful compiler available, and yet you can get it for free.
Likewise, this project is completely free. I'll post everything below: schematics, PCB artwork and files, source code. All I ask in return is that you keep my name on it, spread the word about electro-music Forum, TinyCad, FreePCB and PIC Micro Pascal.
Have fun,
Thomas Henry
Photo of the completed SN-Exerciser
 Filesize:  410.23 KB
 Viewed:  1061 Time(s)
Schematics.pdf
Schematics (2 sheets)
 Filename:  Schematics.pdf
 Filesize:  26.77 KB
 Downloaded:  1506 Time(s)
PCB.pdf
PCB artwork as a .pdf
 Filename:  PCB.pdf
 Filesize:  37.6 KB
 Downloaded:  1234 Time(s)
Parts Placement.pdf
Parts Placement Guide
 Filename:  Parts Placement.pdf
 Filesize:  50.05 KB
 Downloaded:  1200 Time(s)
SN-Exerciser.zip
PIC Micro Pascal firmware source code
 Filename:  SN-Exerciser.zip
 Filesize:  2.65 KB
 Downloaded:  1120 Time(s)
Thomas_Henry
PostPosted: Wed Jan 07, 2015 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is the FreePCB design file.
TH
PCB File.zip
Complete FreePCB design file
 Filename:  PCB File.zip
 Filesize:  12.13 KB
 Downloaded:  1133 Time(s)
LFLab
PostPosted: Wed Jan 07, 2015 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Pretty cool, thanks for sharing!
PostPosted: Wed Jan 07, 2015 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent Smile
Thomas_Henry
PostPosted: Sat Jan 10, 2015 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi again,
It occurs to me that a Picaxe microcontroller could probably be used with the SN-Exercise, with no change to the hardware. Just be sure to specify a 1 MHz clock speed to keep the current drain below what the onboard Zener can provide.
The advantage, of course, is that you won't need a special burner.
Thomas Henry
dukankallemegper
PostPosted: Fri Feb 20, 2015 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a .hex file for this?
Thomas_Henry
PostPosted: Tue Feb 24, 2015 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can find the hex file attached.
Thomas Henry
SN_Exerciser.hex
 Filename:  SN_Exerciser.hex
 Filesize:  4.79 KB
 Downloaded:  1052 Time(s)
dukankallemegper
PostPosted: Fri Feb 27, 2015 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you
Starspawn
PostPosted: Mon Jun 15, 2015 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
So Im thinking of using a softpot for pitch here.
Ive got a 10K 50cm one, so thinking that it might work just putting it where the 100K is now, put the 100K between softpot and 9V with top two legs together (as coarse tune) and done?
Or is some resistor changes in order to make that work?
Thomas_Henry
PostPosted: Sun Jul 23, 2017 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Gang,
Just a heads-up that I've posted all the design files and more information on this project at my PIC blog:
http://pic-in-pascal.blogspot.com/2017/07/complex-sound-generator.html
By the way, I'm up to 96 exercises with schematics there now, with more on the way...
Thomas Henry
PostPosted: Mon Jul 24, 2017 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
The link to the Youtube demo isn't working (on your website it is though..)
my synth
Former site admin
Audio files: 353
PostPosted: Mon Jul 24, 2017 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
https://www.youtube.com/watch?v=3mgB-J8ptWk instead of hNjNtkX1YU4
PostPosted: Mon Jul 24, 2017 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup!
my synth
