2015 Build Pictures
Page 3 of 6 [136 Posts]
J3RK
PostPosted: Tue Mar 31, 2015 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a little Frac system I'm working on right now.
Posted Image
umschmitt
PostPosted: Wed Apr 01, 2015 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Much too much too many beautiful things here!
I was really pissed off last saturday so i built this (a krach orkester… ähm noise ensemble). Guerrilla style.
 Filesize:  220.33 KB
 Viewed:  20233 Time(s)
::U::N::S::C::H::N::E::L::L::
cbfishes
PostPosted: Sun Apr 05, 2015 2:57 pm    Post subject: So much great stuff! Reply with quote  Mark this post and the followings unread
Wow, so much great stuff here. I'm so glad I stumbled upon electro-music in my quest to build stuff that makes noises!
I'm a total newbie to all this, but thanks to these forums and other internet sources I've managed to build a sort of modular. The stuff you all share has been invaluable for helping me make sense of those crazy schematics and stuff.
Some of the modules are totally passive (like the vactrol low pass gate), all are very simple (basic 40106, 555, and op amp-based oscillators). Next step is to build a dual supply so I can finally build a resonant low pass filter (in my mind, that's what I'm missing). Case and panels built with my very minimal woodworking skills and pallets; many components liberated from other items, thrift store toys, even parts of a TV I found in the woods. Patches made with alligator clips, screws, and nuts. Powered off a 5V wall wart. Most of the circuits come from various folks on these forums like synthmonger, Thomas Henry, et al.
Not pictured: I'm using a Raspberry Pi running wiringPi and Mido to listen for MIDI input and scale the 1-127 to 1-100 PWM on the GPIO pins (using a python script). Then I take that through a simple 1-pole low pass filter to get a fairly smooth voltage, which in turn modulates stuff, plays oscillators, etc.
Not the fanciest but it sure does make some noise!
Here's a video of some sounds from a few weeks ago (more modules since then): https://www.youtube.com/watch?v=AR4bPaf7Dwo
Here are some pics:
 Filesize:  99.71 KB
 Viewed:  525 Time(s)
 Filesize:  102.41 KB
 Viewed:  551 Time(s)
making stuff that makes sounds is awesome!
Music/fishing/adventures blog CB Fishes
music.chrisbeckstrom.com
phobos
Audio files: 728
PostPosted: Sun Apr 05, 2015 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always like personalized DIY panels so I really like how that synth looks. And nice to see you're reusing some old stuff.
For a filter you could use the one from Eric Archer which works on a single supply, and sounds quite good. However the
pdf is no longer available, but I have it so just send me a pm if you're interested.
it's been moved and now here
Of course you do want a dual supply anyway. It will make some things easier, and give you more circuits to choose from Wink
I will watch the video later.
The Golden Shrimp Guild
cbfishes
PostPosted: Sun Apr 05, 2015 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa, awesome! Hadn't seen that one yet. To be honest that schematic is pretty intimidating to me– before I tackle something like that I guess I better get a bigger breadboard (mine is the size of an altoids tin). I'm sure it's simple to most folks on here, but I'm just getting started... Gotta work up to using more than 10 components in one circuit!
Probably off topic, but in that schematic what is the "0V"? I get "+9V" and "GND," but not sure "0V."
I've breadboarded various active filters with a LM324 and never have I even been able to get a sound. Probably wiring something wrong every time. Ima keep at it!
Glad you like the panels! Your stuff is very inspirational!
phobos
Audio files: 728
PostPosted: Sun Apr 05, 2015 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy thanks
yeah I can understand it's a bit intimidating but a lot of filters will have a similar setup and once you're
able to see it as the individual blocks it's made of it's get's easier to understand. I'll send you a pm with
some more details.
Just Dave
PostPosted: Mon Apr 06, 2015 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's really pretty. Do you have any sound samples?
umschmitt
PostPosted: Wed Apr 08, 2015 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
As for soundclips, i'm afraid not yet (who knows, i might even get banned from this forum for posting clips of me… playing banjo through it). Soundwise it's more carpet bombing than guerrilla: at minimum delay setting you get a velcro style fuzz, with a bit more of it a nasty slapback, and then further a kind of chorusey thingie and at the end just absurd delayed squelches - all of it square-wavish and all-or-nothingy. Purty brutal.
Anyway should be able to find some info on the webz. Design (not mine) is by an Anchovie up there on DIYstompboxes.
phobos
Audio files: 728
PostPosted: Wed Apr 08, 2015 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
umschmitt wrote:
who knows, i might even get banned from this forum for posting clips of me… playing banjo through it.
anybody who has problem with banjo has probably not listened to Dale Parson Cool
Posted Image
here is a nice example (hmm we should have one with a banjo)
OT: the most recent thing I put together is the NANDulator (special easter edition). more info here
NANDulator
 Filesize:  49.75 KB
 Viewed:  473 Time(s)
umschmitt
PostPosted: Wed Apr 08, 2015 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boah! This NANDulator thing is awesome! (i mean not just the enclosure…) Great sound possibilities despite the simple design. And i suspect further developments.
Anyway. i'm an instant fan and i think we have here the subject for our next DIY electronic workshop! (i guess it'd be ok?)
Back on topic, what can i say except: anybody who has listened to me could probably have all of a sudden a problem with banjo…
phobos
Audio files: 728
PostPosted: Thu Apr 09, 2015 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
of course, feel free to use it in any way you want to, that's why I share the circuits.
PostPosted: Fri Apr 10, 2015 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
Posted Image
Anyone else afflicted with a permanent internal voice saying, "This could be better..." ?
I decided to re-layout the EFM 3046VCO for SMD parts, and with a more Mutable inspired thing, where the only parts visible once done are trimmers and the power connector on the back. Fairly limited as VCO's go (the Square output is anemic, still haven't got around to figuring out why, and it doesn't go very high in frequency), but satisfying nonetheless Smile
I think I've hit my 40W pencil iron's limitations -- the tip was nearly too rounded for the LM3046 IC, and the 47uF caps barely got soldered at all.
isak
PostPosted: Sat Apr 11, 2015 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
Posted Image
Posted Image
Nice build my friend.
Maybe the next post will help you on the square sound:
http://electro-music.com/forum/topic-47625.html
umschmitt
PostPosted: Sat Apr 25, 2015 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
NANDulator!
ghettobling!
 Filesize:  111.13 KB
 Viewed:  19212 Time(s)
PostPosted: Sun Apr 26, 2015 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wasn't sure where to put this. Well, Dad and I spent four or five hours building it, so it's a build Wink
Anyway, big news -- new case time!
Posted Image
Two sets of 2x126hp rails from Elby Designs, power stuff from RS and OSHpark, and formica-covered wood pinched from Dad's workshop (he got it from the skip of a kitchen design place.)
Posted Image
Posted Image
Power arrangements. I seriously need to tidy up the AC wires there. The terminal blocks are so I can add another power board hanging off the same transformer later on (there is a set of drill holes for another PSU board at the top of the case. I also need to order some flying busboards.
So chuffed right now! It looks the money, too!
PostPosted: Sun Apr 26, 2015 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work Smile
vladosh
Audio files: 55
PostPosted: Fri May 01, 2015 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
2 x Buchla 258 , Serge bottom section waveshaper , CV Twister ,all in 42HP eurorack
 Filesize:  1.16 MB
 Viewed:  328 Time(s)
loydb
PostPosted: Sun May 03, 2015 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
My recently-built Zebrawood 168hp 15U case.
Posted Image
Posted Image
Audio files: 163
PostPosted: Sun May 03, 2015 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice case Smile
bubzy
Audio files: 74
PostPosted: Sun May 03, 2015 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
that wood looks awesome, very nice look altogether Smile good luck with filling that, will be a load of fun!
_Richard_ Smile
PostPosted: Mon May 04, 2015 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
Sorted!
Posted Image
This is what it looks like with the front panel off. Hugely fun, this oscillator -- the Timbre and Colour knobs do different things, depending on what waveform you have selected, plus it can decrease the bits, or the sampling rate (96kHz down to stupidly low) and all kinds of fun!
Posted Image
This is what it looked like in it's natural habitat. (Yes, I still have to bolt most of that in -- I've got a busboard on the way and am not hugely bothering until I have things finalized.) The FFB was from when I was playing with the "NOIS" setting.
Actually, at one point, I thought I heard ticking... and my heart SANK and went "oh, shiiiiit..."
luckily, I had just left a clock signal plugged into the 'TRIG' input, and it was doing what it was designed to. I think.
comrade_zero
PostPosted: Thu May 07, 2015 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
@vladosh-- that is a great looking panel!
PostPosted: Tue May 12, 2015 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
Posted Image
Ian Fritz' Jerkster circuit -- a 3rd order autonomous chaos circuit. (No, I'm not completely sure what that means, either!) But it makes cool patterns and noises. The resistors on the pot backs are because I didn't have the right values on hand, so added them to reduce the pot resistance to what the circuit needs.
Posted Image
Posted Image
YUSYNTH Clock Divider. Three separate dividers, each going from divide by 1 to divide by 8. If you just plug an input into #1, then #2 daisychains off it (and #3, in turn, daisychains off #2. There is no input for #3 -- it's the Reset jack.) Very nice lightshow, and I'm sure I'll get good use out of it Very Happy
nicolas3141
PostPosted: Sat May 16, 2015 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Touch sensitive sound generator with 9 contact plates.
 Filesize:  105.29 KB
 Viewed:  293 Time(s)
PostPosted: Sat May 16, 2015 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks lovely and intriguing!
.:James:.
