24db low pass filter calibration question.
Page 1 of 1 [2 Posts]
Europanaut
PostPosted: Tue Oct 28, 2014 3:18 pm    Post subject: 24db low pass filter calibration question. Reply with quote  Mark this post and the followings unread
The calibration procedure for this filter suggests starting with 100hz at 0 volts. I have two filters, and one only goes down to 120hz, and the other goes to 130hz, despite messing around with the trim pot.
I'm curious to know if this is incorrect for the lowest range of self oscillation. If not, are there resistor values that can be messed with to extend the range down further?
Or does it really matter?
Thanks
PostPosted: Tue Oct 28, 2014 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
For calibration it doesn't really matter. 100Hz just makes the doubling relationship easier to see.
I don't know the filter well enough to comment on whether that's within the normal range of this particular circuit.
