Another Sequencer (for drums)
Page 1 of 1 [14 Posts]
bubzy
Audio files: 74
PostPosted: Tue Jan 14, 2014 6:39 am    Post subject: Another Sequencer (for drums) Reply with quote  Mark this post and the followings unread
hello again....
after almost completely giving up on my other sequencer, I have decided to start again but with a more simple idea, this is a 4 gate out drum sequencer, it has tempo setting, shuffle, and random population options, the steps are programmed using buttons to turn them on or off, there is a cycling LED that will show the current step. step length can vary from 1 to 64 steps per gate, so gate 1 can have 8 steps, gate 2 can have 14 steps, gate 3....... you get it. this can allow for some interesting rhythms. there is currently no option to vary the length of the gate out, other than to have a lower BPM, I don't know if this is necessary, as if it was REALLY important, you could use this device to trigger an adsr with a longer time on it.
anyway, heres the current incarnation.
_Richard_ Smile
capicoso
PostPosted: Wed Jan 15, 2014 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Smile
Will you add more features or is it done?
My sequencer has the option to vary the gate time, but i also found it a bit useless. I then put a switch to select gate or trigger, just that.
What happened with the other sequencer?
bubzy
Audio files: 74
PostPosted: Wed Jan 15, 2014 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
the other one got very complicated, I lost a massive chunk of the code and got disheartened, I may revive it sometime, but got a load of other stuff on the go at the moment Very Happy thanks for the interest.
I don't think it will have any other features, im considering a reverse function although I don't know how useful that would be Very Happy
_Richard_ Smile
capicoso
PostPosted: Wed Jan 15, 2014 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
ouch...
that's fine, if we keep adding features it'll never end... The only thing i could think that would be cool is the option to save patterns
bubzy
Audio files: 74
PostPosted: Thu Jan 16, 2014 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah I thought about that, but then theres not a logical way to display it, and im out of pins for I2C :/
_Richard_ Smile
bubzy
Audio files: 74
PostPosted: Thu Jan 16, 2014 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
made the front panel today
 Filesize:  299.62 KB
 Viewed:  617 Time(s)
_Richard_ Smile
bubzy
Audio files: 74
PostPosted: Thu Jan 16, 2014 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
added some doodles to the panel. its all in white so its difficult to photograph :/
 Filesize:  2.19 MB
 Viewed:  520 Time(s)
_Richard_ Smile
roglok
PostPosted: Fri Jan 17, 2014 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
nice sequencer and a lovely panel, richard!
bubzy
Audio files: 74
PostPosted: Sun Feb 02, 2014 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
here is the "finished" version (is DIY stuff ever complete)?
_Richard_ Smile
scriptstyle
PostPosted: Sun Feb 02, 2014 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is cool are you going to post the sketch?
bubzy
Audio files: 74
PostPosted: Mon Feb 03, 2014 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure at the moment, this would mean I would have to get the schematic up to date and everything, then answer questions like "why isn't this working" Very Happy ill consider it over the next couple of weeks (it still needs some tweaks anyway)
_Richard_ Smile
Audio files: 730
PostPosted: Mon Feb 03, 2014 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
looks great bubzy! thumleft I like the green LED's on 4th steps. And I'm curious about how you did the shuffle function, it sounds very good.
The Golden Shrimp Guild
bubzy
Audio files: 74
PostPosted: Mon Feb 03, 2014 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Phobos Very Happy
shuffle took a while.
basically its this
Code:
//pseudocode assuming "shuffle" is switched on.
boolean shuffleState ;
if(shuffleState)
add shuffle interval to "beat"
shuffleState = !shuffleState
else if(!shuffleState)
subtract shuffle Interval from "beat"
//where "beat" is the interval between steps
_Richard_ Smile
bubzy
Audio files: 74
PostPosted: Mon Feb 03, 2014 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
here it is in the box with (some of) the modular Very Happy
 Filesize:  2.11 MB
 Viewed:  486 Time(s)
_Richard_ Smile
