jgoulds
Posted: Mon Feb 25, 2013 10:15 pm Post subject:
Noise Toaster Pots Subject description: Linear v. Log for AR-EG & LFO RAte |
| Just wandering if anyone can tell me how the AR Envelope Generator and the LFO Rate control will behave if I use A1M instead of B1M. I'm thinking it would be fine, but wandering if anyone has any thoughts.. |
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Posted: Tue Feb 26, 2013 8:54 am Post subject:
Hi jgoulds.
Since the three pots are wired up as variable resistors and not true potentiometers (i.e. effectively only two of the three connectors are being used) the only effect will be one of controllability. The linear taper pots (B1M) will give a smooth transition from slow to fast (LFO) or of short to long times (AR EG). With log taper pots (A1M), if I've got my head the right way round, the LFO frequency will change slowly at first and then speed up quickly towards the end of the turn. With the AR EG pots, the length of time for the attack/release will be stay short at first and then will rapidly get longer towards the end of the turn.
So, the answer is, the pots will work, but not as well as the linear taper ones!
Hope that helps,
Gary
EDIT
Sorry, I spotted a mistake in my reply I've now amended it (I put B1M in for both linear and log pots). Hope that it didn't confuse you too much. |
Evercube
Joined: Sep 07, 2014 Posts: 3 Location: United States
Posted: Sun Sep 07, 2014 10:09 am Post subject:
I'm fairly certain I've made the above potentiometer mistake, which is one of the reasons I am combing the forum right now.
I'll try to remember to record and post some before-and-after examples somewhere if this is indeed the case. |
Audio files: 730
Posted: Wed Sep 10, 2014 6:30 am Post subject:
I personally use log. pots for envelope generators, wired so that the time get's longer when turned clockwise.
and reverse log. pots for oscillators, wired so that the frequency get's higher when turned clockwise.
keep in mind that A/B can both mean lin./log. depending on the manufacturer _________________ "My perf, it's full of holes!"
The Golden Shrimp Guild |
