noise cornucopia bleed
Page 1 of 1 [2 Posts]
fluxmonkey
PostPosted: Mon Jun 25, 2012 6:47 pm    Post subject: noise cornucopia bleed Reply with quote  Mark this post and the followings unread
having a little trouble w/ the noise cornucopia picking up stray signal from other modules in the rig and amplifying it along w/ the desired noise. basically adds a background "tone" to the noise... not overwhelming, but now that i've noticed it i can't help noticing it. tried tracking down the source, but there's about 45 modules in that case, and i think it's a combination, not one specific offender. i added a pair of ferrite beads in series w/ the power in, helps a bit but not much. any suggestions?
www.fluxmonkey.com
Feifer
PostPosted: Mon Jun 25, 2012 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
How much capacitance do you have on your power supply? If you don't have enough I've found it's possible for your vco signal to leak back up the lines and pop up somewhere else. Are all 45 modules powered by the same PS? I would unplug all your patches, put your power supply on a scope, AC couple and see what you see.
