SV VCF LP to HP
isak
PostPosted: Fri Jun 22, 2012 8:14 am    Post subject:  SV VCF LP to HP Reply with quote  Mark this post and the followings unread
Hi Guys.
i'v built the MFOS SV VCF and as i understand i can put from the output all three modes (LP,BP,HP) simultaneously.
i want to make a mod that gives me the option to go from LP to HP.
how would i do that?
is it possible to do it with one board?
my thinking was to take the LP and HP audio outputs put them in a pot pin 1 and pin 3 but it will give me only the option to move from LP to HP without controlling the cutoff pot, so i thought with the same pot to connect it to the cutoff.
maybe a dual 100k pot? like this..
http://www.ebay.com/itm/100K-OHM-Linear-Dual-Taper-Rotary-Potentiometers-B100K-100KB-POT-ALPHA-/260944291837?pt=LH_DefaultDomain_0&hash=item3cc17de7fd#ht_1455wt_910
if you have a better idea on how to do it ill be happy to hear Smile
Isak E.
