MFOS LM317/LM337
Page 1 of 1 [4 Posts]
LIOZPRAV
PostPosted: Mon May 07, 2012 2:10 pm    Post subject: MFOS LM317/LM337
Subject description: for modular synth?
hi everyone..
im building my first modules.. two from yusynth and one of ACXsynth..
and of course i need a power source unit
is the LM317/LM337 the right choice for this??
also.. i live in chile and the voltage in here is 220v. should i modify some of the components or i leave like that? also.. what kind of transformer should i use?? can it feed the 3 modules???
thanks!!!! Razz
ashleym
PostPosted: Wed May 09, 2012 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes this power supply will work. I have looked up the ACXsynth and it needs 15v, I havent looked at the Yusynth modules but if they also use a 15v supply you will be OK. The variable resistors in the circuit will let you set the output voltage to +/-15. The transformer type is up to you. I prefer toroidal as they offer a bit more regulation than frame transformers. The supply gives out about 1.5A and most modules require about 100mA, so you have enough current for up to 15 modules but it might be less in real life because of differing current requirements and it isnt best practice to max out your supplies.
Audio files: 730
PostPosted: Wed May 09, 2012 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I like to add, that for a +/-15V supply you'll need a 2x 18V~ transformer.
I used a 50VA toroid myself,. but you can do with less if you're not
planning to power more modules with it in the future.
The Golden Shrimp Guild
LIOZPRAV
PostPosted: Wed May 09, 2012 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys!! ill post pictures of my prgress haaha Very Happy
