Multiplier problems
Page 1 of 1 [3 Posts]
Pehr
PostPosted: Wed Nov 30, 2011 1:21 am    Post subject: Multiplier problems Reply with quote  Mark this post and the followings unread
I've built the sonic multiplier, but the onboard oscillator is behaving strange.
At low settings it was not oscillating at all and fully CW it was not reaching higher than 1000 Hz
I had to make some adjustments (changing resistor values) in order to have it in the range I wanted.
But now the tracking is totally weird. It goes from low to high freq very fast somewhere around 11 o'clock.
Could it be something wrong with the transistors Q1-Q3?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
jordroid
PostPosted: Wed Nov 30, 2011 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This seems to come up now and again, the oscillator in the sonic multiplier is a State Variable Filter, set to permanently oscillate. If conditions are not just right it may not oscillate over a wide range or may have trouble getting started.
There have been a couple of threads about this, here is one http://electro-music.com/forum/topic-31767.html&sid=ea1a861d2dcb0f81520b775ed32173a8
It should track at 1v/oct fairly well (as well as a filter can), so if your tracking seems weird, check out everything around U1 and Q1, Q2 and Q3 like you suspected. If you have changed any of the resistors in the feedback loops of U1A, B or C, or any resistors going from an opamp output to an opamp inverting input that would mess with the tracking. Maybe best to check it with a 1v/oct source to see how closely it tracks?
If you changed R21 or R24 to get the range closer to where you want it, that could alter the way the taper of the coarse tune pot feels.
I think a better way to have the coarse tuner set up is to remove R21 and R24 altogether, and alter the value of R26 (probably make it bigger) to get the coarse tuner to have the range you desire, same goes for the fine tuner. I'm sure Ray spent a bunch of time coming up with those values, so his way should work well, it just seems like four unnecessary resistors, and they can make the taper of the pots feel weird if they are unequal in value.
You probably want linear pots for the tuners, a log pot would almost surely feel wrong.
Let us know how it goes,
regards,
jordan
Pehr
PostPosted: Wed Nov 30, 2011 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the extensive reply Smile
I think my memory is failing me on this case. The initial problem was that the frequency was too high for all pot settings. I removed R21 and R24 and lowered R26. But then the oscillator stopped for low frequencies. Thus, I lowered R46 to 100k. Now I have good range, but wrong response.
First I need to measure how off the tracking ism and then investigate Q1-Q3.
btw, I really like the preamps on this thing Smile
YouTube channel
flickr photostream
