A simple mod for the Dual VCA
Page 1 of 1 [2 Posts]
Mongo1
PostPosted: Sun Sep 04, 2011 2:46 pm    Post subject: A simple mod for the Dual VCA
Subject description: Add 'MUTE' with one component change.
Here's a little mod you can do to the MFOS Dual VCA - It's easy and cheap, and actually does something pretty useful.
In the standard design, the switch that selects Linear vs Log is a simple SPDT switch. The mod I'm talking about just requires replacing that switch with a 3 position (on-off-on) switch.
With the new switch, the Linear and Log positions work just as before. But when you place the switch in the center position, no current gets through to the amplifier, and therefore the amp goes quiet.
This comes in pretty handy. Once you have the gain adjusted the way you want it, you can switch the amp on and off without disturbing that setting.
Gary
sonicwarrior
PostPosted: Fri Jun 01, 2012 1:11 pm    Post subject: Re: A simple mod for the Dual VCA
Thanks for this tip. I'm currently building two Dual VCA and used this mod. Very handy. thanks
