 Forum index » Instruments and Equipment » Soft synths
Wobble Meister
Page 1 of 1 [3 Posts]
Oweng4000
PostPosted: Sun Jun 05, 2011 12:42 pm    Post subject: Wobble Meister
Subject description: A Wobble Bass plugin I designed
Here it is. I spent a long time on this, like 6 hours, so please be nice. I'm open to suggestions.
The base of it is is Two square wave oscillators(OSC 1 and OSC 2). OSC 1 is synced to a third square wave, whose frequency is adjustable. OSC 2 is detune able. These are then mixed together. You can also add in white noise. All three of these then go through a low pass filter, whose cutoff is adjusted by a L.F.O. whose waveform is selectable. The L.F.O.'s frequency is set by either a slider or a random function. The output of the Low pass filter is sent through a distortion. The output of the distortion is sent to the master volume, which is then sent to the output.
Wobble Meister.zip
Wobble Meister In AU and VST format
 Filename:  Wobble Meister.zip
 Filesize:  147.81 KB
 Downloaded:  805 Time(s)
Oweng4000
PostPosted: Tue Jun 07, 2011 10:50 am    Post subject: V2 Reply with quote  Mark this post and the followings unread
Updated with Ring Mod, and Oscillator Level Controls.
Wobble Meister V2.zip
 Filename:  Wobble Meister V2.zip
 Filesize:  149.7 KB
 Downloaded:  803 Time(s)
Kabzoer
PostPosted: Wed Jul 27, 2011 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I couldn't open it in FL studio 10 Sad
