egasimus
egasimus
Posted: Thu May 12, 2011 4:51 pm Post subject:
Fixed, I think. Now it's a bit smaller and has caps on the power rails (only 100uF electrolytics, though, didn't have room to shunt them with some 100nF ones or so). Little, if any, is left of the original abuse of curve tool, now replaced with abuse of diagonal traces. The component layout looks kinda prettier, it's fun making those:
Sebo
Posted: Sun May 15, 2011 3:27 pm Post subject:
Thank you!!!
I will try it in a near future!!! _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
egasimus
Posted: Sat May 21, 2011 3:43 am Post subject:
Note that there's too little clearance around the three square pads - I'll make some room (perhaps move the pot a little) and fix that, too, but until I do, take care not to short them  |
Sebo
haxster
Joined: Feb 01, 2006 Posts: 246 Location: MONTEREY PARK, CA 91754
Posted: Fri May 27, 2011 3:58 pm Post subject:
If you add a 50k or 100k trimmer with the outer pins going to + and - and the middle pin to a 100k resistor and add that little circuit to the Main CV Line (where all the CV's mix or meet) you will make it work universal for all Voltage Power Formats. It will act as a Cutoff Range Offset.
It is worth the extra redesigning. |
egasimus
Posted: Mon May 30, 2011 11:08 am Post subject:
That's exactly the kind of feedback I need This will definitely go into the next revision. |
egasimus
Sebo
Posted: Tue Jul 12, 2011 4:02 pm Post subject:
Thank you.
Did you tested this version? _________________ Sebo
My Music:
egasimus
Posted: Thu Jul 14, 2011 9:58 am Post subject:
| Nope, but a guy at another forum already volunteered, and I myself got the ICs today, so it might be verified soon. |
tokyomatik
Audio files: 6
Posted: Wed Aug 10, 2011 3:50 am Post subject:
it looks pretty easy
any news? is it working? somebody tested?.... |
egasimus
Posted: Fri Aug 12, 2011 6:28 am Post subject:
| No :/ The guy who tried to build it only got so far, but I haven't heard from him for a while. I think he had some problems with the power supply - he's a guitar stompbox guy, just like me. I'm hopefully gonna build my own bipolar PSU soon, though, so I'll eventually get around to testing it. Sorry :/ |
n.d
Posted: Sun Jan 29, 2012 7:05 pm Post subject:
| Hi there. Any news? Sebo? Anyone? |
tokyomatik
Audio files: 6
Posted: Mon Jan 30, 2012 6:33 am Post subject:
| I start to think that the only solution is trying to etch a board and see if it work..... |
-minus-
Posted: Mon Jan 30, 2012 6:59 am Post subject:
Can someone actually upload an image without having to go through all the hassle of links to other sites and zip files please?
2Shared The Easiest Way To Share Files... clearly is NOT the easiest. I can't get the file to download at all.  |
n.d
n.d
Posted: Mon Jan 30, 2012 12:05 pm Post subject:
Please report back if you build it.
And egasimus, do you have the eagle - or kicad, altium, whatever- files? |
Sebo
Posted: Tue Jan 31, 2012 1:31 pm Post subject:
I had the PCB etched for a while, but didn't had the time to solder anything yet... _________________ Sebo
My Music:
tokyomatik
Audio files: 6
Posted: Thu Feb 09, 2012 11:51 am Post subject:
| any news about this board?? |
tokyomatik
Audio files: 6
Posted: Thu Mar 08, 2012 7:14 am Post subject:
....so????  |
Sebo
Sebo
Posted: Sat Jun 02, 2012 6:48 am Post subject:
Hi:
I just finished my Polivoks VCF using this PCB and I can confirm it works.
I just did some mods to improve the cutoff range and the CV inputs sensitivity, but this mods are the same all people do to the Marc Bareille version.
Thanks again to egasimus for share!!! _________________ Sebo
My Music:
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Mon Jun 04, 2012 3:05 am Post subject:
I've etched a board for this thing, but haven't found time to assemble it into a module (and since I want it to be a dual, will need to etch another board).
What mods did you do to improve cutoff range and CV input sensitivity? Will need to see if I can change the layout slightly to incorporate the changes. Would also be nice to have a euro style power connector, since I have them on the bussboards in my cabinets, that's an easy enough addition.
Edit:
Did you tie the cutoff to V- with a resistor? That's also a mod for the SSM2044 VCF, helps tremendously. |
Sebo
Posted: Mon Jun 04, 2012 8:28 am Post subject:
To imporve cutoff range I wired the side of the cutoff pot that goes to ground to -15V instead. Also changed R8 to 270K and put a 50K trimpot in series to finetune (I think I ended with a total resistance of 290K aprox).
To improve the CV sensitivity I changed R5 and R9 to 150K. _________________ Sebo
My Music:
mrkva
Joined: Jan 25, 2012 Posts: 41 Location: poland/slovakia/netherlands
Posted: Wed Jan 30, 2013 10:09 am Post subject:
| How would one adjust this shematic for +/- 12V? Thank you |
