intercepting oscillators and stuff
Page 1 of 1 [5 Posts]
synthesist
PostPosted: Sun Apr 24, 2011 1:05 pm    Post subject: intercepting oscillators and stuff Reply with quote  Mark this post and the followings unread
hey,
I am still trying to build my stripboard soundlab mini synth and there are still so many troubles.
One thing is that I can listen to my oscillators if they are plugged straight into my diy-amplifier. The sound is damn loud. Actually I can already pick up the oscillators when they share the same ground-connection with the amp.
But if I pick up the signal after it passes the filter and the vca, the sound is so silent - I almost cant hear it.
My question is: what kind of amp or preamp do you normally use to play your soundlab? I mean my hommade amp sucks, but I can listen to my weird sound generator with it.
By the way,
The volume poteniometers are weird. If I turn them halfway clockwise, the sound gets louder, but if I go on and turn it all the way, it gets more silent again!?
please help me.
RF
Audio files: 28
PostPosted: Mon Apr 25, 2011 8:19 pm    Post subject: Re: intercepting oscillators and stuff Reply with quote  Mark this post and the followings unread
It sounds like you are not getting a CV into the VCA. Turn the Master volume up, and back off the VCA just a tad...then either the LFO or the Envelope Generator into the VCA should allow you to hear the volume getting louder and softer.
Most any amp should work fine. I've used 386 amps to computer speakers to PA systems with my Soundlab.
synthesist wrote:
By the way,
That sounds like you've got the pot wired wrong.
You'll get it figured out... Smile Focus on one issue at a time. I'd start with the volume pot. Hang in there - and let us know how you are doing. Troubleshooting is just part of DIY, and most of the people here will be glad to help.
good luck!
bruce
www.sdiy.org/rfeng
synthesist
PostPosted: Mon May 02, 2011 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey RF,
thanks for your help.
It took some time to reply, cause i had to make a real faceplate. The first one was made of cardboard...
I am pretty new in this buisness, but I am sure I didnt wire the pots wrong.
Pin 1 gets the signal, Pin 2 is the wiper - it leads the attenuadet signal to the VCF, Pin 3 goes to ground. I used 3% tolerated resistors between the pots and the VCF (R30, R33, R39), may this be a problem?
The pots really act totally crazy. They are not really mixing like they should.
The white noise gets loud if I turn the oscillator 2 off all the way. I can hear oscillator 1 only when turned on all the way - but then it gets too loud... and so on...
There is also something wrong with the LFO, but right now I am picking up the signal at the VCF output. It is loud enough and sometimes it sounds mindblowing good.
So if the VCA doesnt get a CV it shouldn't matter at the moment.
I am pretty sure that the mixer is the problem.
I thought about making a photograph-picture of my stripboard-frankenstein-soundlab. But if I would release it on the forum, you wouldnt want to help me anymore Sad
also I would lose my dignity Sad
and maybe they would clear my profile from this forum... Sad(
bye.
kjackman
PostPosted: Tue May 03, 2011 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nah, I seriously doubt any of that would happen. We've all been there at one time or another. Everyone here started as a beginner. Some of us still are.
Learning to troubleshoot is hard. Learning it completely on your own without support is just plain crazy!
synthesist
PostPosted: Tue May 03, 2011 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah!
I fixed the mixer. The volume pot for oscillator 1 must have been broken -so I replaced it.
Also I forgot to ground the resonance pot - so the filter selfoscillated the whole time.
Today I will try to fix the VCA and LFO.
