MFOS VCO Problems
Page 1 of 1 [7 Posts]
kjackman
PostPosted: Thu Apr 14, 2011 10:33 pm    Post subject: MFOS VCO Problems
Subject description: Something's not right...
I'm trying to breadboard the VCO before building it. I want to understand it well enough to troubleshoot if something goes wrong. I built everything below except for the linear input, sync input, and HF compensation. I get some kind of wave on the output. but it's 0.8mv p-p, and the frequency (8k?) never changes, no matter how I twiddle the coarse and fine freq knobs. Also, the wave looks more like a very much rounded sawtooth or something.
In the diagram below, I show what the output of the summer stage and the first op amp look like before I attached the later stages.
I did not build any other parts of the circuit from other schematic pages. Does that make a difference?
Posted Image
VCOProblems by kjackman, on Flickr
I'm pretty sure all the components are connected correctly; I double-triple checked everything.
Any help would be much appreciated, thanks!
prgdeltablues
Audio files: 12
PostPosted: Fri Apr 15, 2011 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Two thoughts:
Pin 2 of U1A is a virtual ground, so you should read 0V there, and the range you report at that point isn't right for the coarse/fine controls - try measuring on the other end of R8 - you should get a range from about +7V to -10V. You should measure about 20mV change at pin 1 of U1A for every 1V change in the input.
You say you omitted the HF compensation - not clear whether you have anything in the feedback loop of U1B (pin 7 U1B to pin 7 U3) You need the diode and about 20k resistance, even if you don't use a trimmer.
hope this helps.
Peter
jordroid
PostPosted: Fri Apr 15, 2011 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoops Embarassed this one might be my fault, from your last thread, i was writing too fast and not thinking everything through... prgdeltablues is right (about the feedback loop), sorry! I always mean to add a disclaimer stating that anything i say could easily be wrong and should be double checked by someone more experienced, but sometimes i forget to. Good luck with the VCO,
jordan
kjackman
PostPosted: Fri Apr 15, 2011 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Pin 2 of U1A is a virtual ground, so you should read 0V there...
Yep, those are the readings I get out of the summer before hooking it up to U1-A. I'll check those again tonight to see if I can get the proper voltages.
I'll go ahead and put in the entire feedback loop, including the 20k trimmer. That does make sense - there should be some kind of feedback there. The build notes say we can leave those parts off if we don't want HF compensation, and I meant to check the PCB for an alternate feedback route when those parts aren't installed, but I pretty much forgot about that.
As a next step in troubleshooting, I really should have added in all the stuff I'd left off for "simplification" before posting. Then again, seeing threads like these has helped me troubleshoot things in the past. My mistakes might help someone in the future, so I won't feel too bad about posting before trying absolutely everything. Rolling Eyes
I'll give it another try tonight and let you all know how it goes.
p.s. No worries, Jordan, every idea and suggestion helps, even if it just points me (or someone else) in the right direction. I wouldn't want you to not post, just because you're not 100% sure about something.
kjackman
PostPosted: Sat Apr 16, 2011 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed the problem with the coarse/fine tune knobs, sort of. The 47k and 10k resistors were swapped, so I put them in the proper place. I get something closer to the desired range (+4.12 to -9.59), but it's still not quite right. Enough to dial in usable voltages, though.
I put the HF compensation and feedback line in place.
I discovered I had hooked the 100ohm scale trimmer trimpot up to U1 pin 2 instead of pin 1 (how did I miss that for so long?). So I fixed that.
The circuit behaves somewhat differently, but still wrong. I get a rounded sawtooth that changes amplitude (but not frequency) when I adjust the knobs. I tried to measure the current feeding U2-A pin 2, but got zero micro-amps (?). Huh.
I unhooked U1-A pin 1 from the rest of the circuit to double-check that I get that inverted 20mV per 1V amplification you mentioned before. I disconnected R16 and R19 from pin 1. Then I disconnected the CV input chain (pin 2 of R8, the input voltage) from the op amp so I could measure the incoming voltage there, then plugged it back into pin 2 of the op amp and measured the voltage at pin 1 (the output voltage). Here's what I got:
Code:
INPUT | OUTPUT
-8.0v | 0.148v
-7.0v | 0.125v
      | 0.023v = 23 mV ... YES!
...so at least that first op amp seems to be doing what it should do. Of course, that part of the circuit is about as basic as it gets -- op amps 101.
The next stage of the circuit, presumably the expo converter, I don't understand nearly so well. Any thoughts about what I should measure and where?
kjackman
PostPosted: Sun Apr 17, 2011 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the expo converter is working, too. It looks like I'm getting the kind of exponential current increases Ray describes on his VCO notes:
Linear changes in voltage applied to the CV1 through CV4 inputs of U1-A are converted to exponential changes in current at the current sink (collector of NPN transistor at pins 1(c), 2(b) and 3(e) of the SSM2210 Super Matched NPN Pair IC). For each additional volt of CV there is a doubling of the current flowing into pin 1 of U3.
I ran "U3 pin 1" (collector of a 2N3904 since I'm using discrete components) through my multimeter to ground and took some measurements:
Posted Image
So I think everything up to this stage is good.
But I'm still not seeing the 0 to +2.2v ramp wave at U2-A pin 1.
The osc stage is made up of an integrator (U2-A + C6) and a comparator (U2-B and its associated components). Since it looks I'm getting the right current out of the expo stage, I went ahead and plugged that back into U2 pin 2. Ray's notes say that I should see a steady +2V on the inverting input of U2-B, and I do see that. So far, so good. He also says pin 7 (output of U2-B) should measure -10.6V nearly all the time, except for 3μsec pulses of +8V when C6 gets fully charged. I tried looking at this with my portable digital oscilloscope, but didn't seem to see any signal there. With my multimeter, I measured +10.94. Hmm.
Quick question: Does C18 really have to be precisely 4.7pF? The only caps I have that measure precisely 4.7pF are fat 1Kv ceramics. Would 4pF work just as well?
kjackman
PostPosted: Sun Apr 17, 2011 4:53 pm    Post subject: SOLVED! Reply with quote  Mark this post and the followings unread
That is all
