MFOS experimenters/S&H
Page 1 of 1 [6 Posts]
textual
PostPosted: Tue Apr 05, 2011 4:57 pm    Post subject: MFOS experimenters/S&H Reply with quote  Mark this post and the followings unread
just finished this. 2 MFOS experimenter PCBs, Sample and Hold, wall wart for power. Info is at videos as well..
I have been patching on this thing for about 4 hours straight. It is quite a beast. Has some quirks but, pretty amazing.
______________________
www.dlbelectronics.com
www.textualmusic.com
www.mercuryprogram.com
iopop3
PostPosted: Tue Apr 05, 2011 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see someone using the experimenter pcbs. Have no sound at work, but it looks good. Any chance of a few close ups on your panel? Looks like you're using davies knobs as well. Bananas need davies clones.
textual
PostPosted: Wed Apr 06, 2011 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, i will attach a photo.. this is the best I have at the moment, but if you zoom in, you can see the print.. unfortunately there are some errors.. for instance the AR's are NOT ADSR as the print suggest (what was i thinking?) also the 1 of the attenuators is marked with 2 inputs instead of input/output, and all the CVs say 'CV where they should say input (black jacks)
also- i printed the graphics sheets from a different printer, and somehow the size was adjusted just slightly enough to throw it all out of whack., hence the weird cut outs and gaff tape to cover bad looking seems.. ugh, lesson learned.. don't laminate until you have the correct graphics in hand, checked against the plate!
 Filesize:  2.04 MB
 Viewed:  399 Time(s)
iopop3
PostPosted: Wed Apr 06, 2011 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for posting that image.
Thats a fairly large panel, right?
ashleym
PostPosted: Wed Apr 06, 2011 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've seen better videos but I haven't seen many better MFOS kits. Very nice!! Well done and thanks for sharing.
textual
PostPosted: Thu Apr 07, 2011 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
the panel is basically 10x16"
