 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
Chopper
Page 1 of 1 [3 Posts]
Rix
G2 patch files: 25
PostPosted: Sun Jan 02, 2005 5:25 am    Post subject: Chopper Reply with quote  Mark this post and the followings unread
A filter chopper. Basically you play a chord and the sound is chopped up in different filter areas (low, mid, hi, hihi) by different clocks.
5 variations show the possibilities....
One strange thing I noticed: when I hold a key the clock generator is stopped. I do not see why this happens.
Richard
chopperFilter.pch2
A signal is chopped up in different frequency bands, that are enhanced rythmically.
Audio in signals can also be routed through.
 Filename:  chopperFilter.pch2
 Filesize:  2.98 KB
 Downloaded:  1849 Time(s)
Former site admin
Audio files: 353
PostPosted: Sun Jan 02, 2005 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea.
Probably the clock is not stopped (not here it is), but you use a mix of keyboard gating and patched gating for the envelopes.
I'd try to set the keyboard gating off on the envelopes. Or when you want keyboard gating as well, I'd try to set the envelope modules into trigger mode (instead of the gate mode which is used now).
Hope that helps.
Jan.
Rix
G2 patch files: 25
PostPosted: Sun Jan 02, 2005 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, turning the KB trigger off did the trick. thanks.
If you use variation 3 and play a Amin chord followed by a F chord(second position) you can sort of hear the intro of "Don't you want me baby"by the Human League....
