 Forum index » Clavia Nord Modular » G2 Performances - Experimental
ensomber
Page 1 of 1 [5 Posts]
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Sat Dec 11, 2004 1:38 pm    Post subject: ensomber Reply with quote  Mark this post and the followings unread
This is just an experiment with randomising the timing of random notes in a musically constrained way. The circuit in Green (SlotA) uses the SeqCtr to ‘lookup’ one of 16 values which, when applied to a A2D, produce a bit sequence corresponding to 1,2 or 3 gates of varying duration. A couple of DlyClock modules shift the whole pattern one or two and a bit bars for gating the brass and sax slots
ensomber.mp3
audio
 Filesize:  829.74 KB
 Duration: 1:01
 Viewed:  2108 Time(s)
ensomber.prf2
random gate timing experiment
 Filename:  ensomber.prf2
 Filesize:  13.35 KB
 Downloaded:  2267 Time(s)
Audio files: 266
PostPosted: Sat Dec 11, 2004 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
It sounds very "musical". Laughing
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Sat Dec 11, 2004 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Howard, I shouldn’t use the term musical, what I meant was ‘rigidly conforming to equal divisions of a bar’. Not the same thing by any means. Smile
I find the way the note patterns are temporally shifted, but all use the current pitch/velocity a little interesting.
Audio files: 266
PostPosted: Sat Dec 11, 2004 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it is pretty intesting. I'm enjoying it. I've played it in the background for several hours while trying to install a security patch on the forum software. I've modified this software so much that everytime the developers release an update I have to work for hours. You noodle makes it more enjoyable. I which the G2 could hack code too. Laughing
Former site admin
Audio files: 353
PostPosted: Sat Dec 11, 2004 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
For me as well it would be good company when unhacking something, or writing software, things like that, it certainly keeps you going.
And don't get me wrong, it's a very good patch, I think, and it has a lively structure, timewise,, but I'd like it to be a lot more nasty,sound wise; it now hurts my teeth a bit, and I'm more into salty licorice I think :-)
But ... I've been having it on for over half an hour ...
Jan.
