Audio files: 19
Posted: Thu Jul 01, 2010 1:28 pm Post subject:
Microsoft announces "Instaload" Subject description: Probably the best idea MS haver ever had! |
| Quote: | | Battery contacts designed based on InstaLoad™ technology enable users to insert batteries into a device in either + or - direction and the device simply works. Users do not have to search for a hard to read diagram to determine how to insert the batteries. |
Now, THIS is a great idea!!
http://www.microsoft.com/hardware/mouseandkeyboard/licensing/instaloadoverview.mspx _________________ ACHTUNG!
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jul 01, 2010 3:16 pm Post subject:
It's the female conspiracy: again something they don't need men anymore...
Wout |
seraph
Editor
Audio files: 33
Posted: Thu Jul 01, 2010 3:39 pm Post subject:
why didn't they call it iLoad  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
bachus
Joined: Feb 29, 2004 Posts: 2924 Location: Up in that tree over there.
Posted: Thu Jul 01, 2010 3:49 pm Post subject:
Uhhh ... wouldn't that require nothing more than a full wave bridge rectifier? Embarrassingly low tech ... but I guess it's the thought that counts  _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham |
Former site admin
Audio files: 353
Posted: Thu Jul 01, 2010 3:54 pm Post subject:
| it would need two rectifier bridges ... those would drop some of the precious 1.5 V too ... so probably they made something smarter. |
nobody
Posted: Thu Jul 01, 2010 4:11 pm Post subject:
No! No, no, no, no, no!
I'm completely against anything that encourages even MORE stupidity and the demise of intelligence in homo sapiens.
LEARN TO PUT THE FRICKING BATTERIES IN CORRECTLY!
If you can't do it, step away from the battery. Slowly.
FFS, if you can't figure out the + and - ends of a battery, you probably should not be allowed to live alone.
What's next, allowing people to put batteries in at what would normally be the incorrect angle (90 degrees to the contacts) because they don't know what contacts are? How about just showing the batteries to the mouse and the mouse eats them? |
DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Thu Jul 01, 2010 4:18 pm Post subject:
^ +1
I'm going to launch a toothbrush with a brush at each end of the handle. Same idea for matches. Next up are refrigerator doors that can be opened both to the left and right, as well as up and down. There are endless opportunities ahead
DJ
Former site admin
Audio files: 353
Posted: Thu Jul 01, 2010 4:33 pm Post subject:
| audiodef wrote: | | How about just showing the batteries to the mouse and the mouse eats them? |
Brilliant  |
bachus
Posted: Thu Jul 01, 2010 4:38 pm Post subject:
| Blue Hell wrote: | | it would need two rectifier bridges ... those would drop some of the precious 1.5 V too ... so probably they made something smarter. |
You mean a single full-wave bridge would not do it
But yea the likely 0.7V drop would be a problem when the supply is only 1.5v[/url] _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham |
nobody
Posted: Thu Jul 01, 2010 4:42 pm Post subject:
| DrJustice wrote: | ^ +1
DJ
Computer monitors that work on both sides. Televisions that can be watched from any room in the house - without moving them or piping the video around. Cell phones that can be held upside down or backwards.
How about some audio gear? Speakers that sound great no matter where you place them. Mixers that magically create "the perfect mix" for you. Synthesizers that give you their opinions - whether you want them or not (I think we already have some of those). Patch cables that extend or shorten to the correct length (actually, this would be extremely practical). Headphones that adapt to the wearer and refuse to go to a level of loudness harmful to that wearer (again, actually practical).
Hm... sounds like the "it just works" approach would be practical for audio without being damaging to intelligence. |
Former site admin
Audio files: 353
Posted: Thu Jul 01, 2010 5:03 pm Post subject:
One for each battery to support the four permutations of two .. you found a cheaper way to do it? |
Audio files: 373
Posted: Thu Jul 01, 2010 11:06 pm Post subject:
Oh the hours I spend every day, wondering which way to put the batteries in.
seraph
Editor
Audio files: 33
Posted: Thu Jul 01, 2010 11:22 pm Post subject:
| DrJustice wrote: | endless opportunities ahead |
it also indicates the decadence of Western civilization  _________________ homepage - blog - forum - youtube
Audio files: 19
Posted: Fri Jul 02, 2010 12:00 am Post subject:
Hang on....
A bridge rectifier only works on AC?
You would need two- and even then it wouldn't work!  _________________ ACHTUNG!
Former site admin
Audio files: 353
Posted: Fri Jul 02, 2010 1:28 am Post subject:
| v-un-v wrote: | | A bridge rectifier only works on AC? |
Ermm .. no ..
or consider the battery to be rotating very slowly. |
bachus
Posted: Fri Jul 02, 2010 5:48 am Post subject:
| Blue Hell wrote: | | One for each battery to support the four permutations of two .. you found a cheaper way to do it? |
Nope, one per slowly rotating battery it is.  _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham |
Audio files: 19
Posted: Fri Jul 02, 2010 6:52 am Post subject:
| Blue Hell wrote: |
Ermm .. no ..
Oh poo. I used to be quite good at this sort of stuff. Where has my brain gone? (7 years of little or no sleep!) _________________ ACHTUNG!
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 2081 Location: Berks County, PA
Audio files: 90
Posted: Fri Jul 02, 2010 7:31 am Post subject:
| v-un-v wrote: | | Blue Hell wrote: |
Ermm .. no ..
Oh poo. I used to be quite good at this sort of stuff. Where has my brain gone? (7 years of little or no sleep!) |
It comes from relying on those easy-to-use Macs
Dealing with Windoze keeps one's brain engaged  _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
Inventor
Audio files: 270
Posted: Fri Jul 02, 2010 8:04 am Post subject:
There would be no 1.5V diode drop if you used my MOSFET based rectifier. But who gives a damn about my inventions anyway?
Inventor
Audio files: 270
Audio files: 19
Posted: Fri Jul 02, 2010 8:24 am Post subject:
| Acoustic Interloper wrote: |
Dealing with Windoze keeps one's brain engaged  |
I can tell you this, and I'm not gonna tell you much more than this, but the amount of hoops and loops and red tape I have had to deal with over the last 16 weeks or so, working within Xcode and using an SCM repository within an svnX Server, has been pure hell. If you really think that an Apple is an easy-to-use alternative, then you really need your head testing!
No offence.  _________________ ACHTUNG!
Former site admin
Audio files: 353
Posted: Fri Jul 02, 2010 10:13 am Post subject:
| Inventor wrote: | | There would be no 1.5V diode drop if you used my MOSFET based rectifier. But who gives a damn about my inventions anyway? |
Dunno ... actually I think that is exactly what is being used  |
Inventor
Audio files: 270
Posted: Fri Jul 02, 2010 10:18 am Post subject:
| Blue Hell wrote: | | Inventor wrote: | | There would be no 1.5V diode drop if you used my MOSFET based rectifier. But who gives a damn about my inventions anyway? |
It looked like a mechanical design to me, with + and - terminals at both ends, concentric. My MOSFET bridge would work with existing batteries and would not require any special contacts - well, it would require a tap at each contact, but that's no big deal.
Former site admin
Audio files: 353
Posted: Fri Jul 02, 2010 10:22 am Post subject:
| Inventor wrote: | | It looked like a mechanical design to me, with + and - terminals at both ends, concentric. |
Yup .. you are right ... didnt look far enough  |
nobody
Posted: Fri Jul 02, 2010 10:24 am Post subject:
| Inventor wrote: | There would be no 1.5V diode drop if you used my MOSFET based rectifier. But who gives a damn about my inventions anyway?
Les |
I do!
Still want one of your electric guitar mods. If we can get it on my Strat Squier II, we have a sale! |
