adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Sun May 02, 2010 12:24 pm Post subject:
Transistor matching for soundlab |
I'm just about to finish off my stripboard soundlab (x2) and i was wondering if anybody matched their tansistor pairs or purchased ssm2210ps. I would like to use the ssm but they are a b'stard to get hold of. Oakley sell them for £5.50 each but would it be better to build Rays transistor matching rig and match up 3904s that way. Oh yeah the 2k resistors r60-61, anyone go the temp comp route. Elby sell wire wound 3300ppm 2k resistors for $8 each. Just would like to hear what you guys used for this little synth. Cheers.  |
jordroid
Joined: Jan 17, 2010 Posts: 193 Location: ithaca, new york
Posted: Mon May 03, 2010 5:54 am Post subject:
I built Ray's transistor matching circuit on a bit of breadboard, it's a pretty simple to make and it seemed to work fine for me. I was surprised at how closely matched almost all of the transistors were within a batch, matching them almost seemed pointless. It's easy enough to do though so why not.
Mine tracks nicely over about four octaves, maybe a little less, but i bet i could squeeze a bit more out of it by spending some more time trimming.
I cheaped out and didn't install the tempco resistors and i do notice some drifting over time, i think it will be well worth it to install the tempcos and i plan to eventually, but it is quite usable without them.
Have fun, it's a great little synth! |
adambee7
Posted: Mon May 03, 2010 8:17 am Post subject:
nice one. I'll give it a go as i have loads of 2n3904s from the same batch. cheers.  |
adambee7
Posted: Tue May 04, 2010 8:25 pm Post subject:
In ray's schematic for his matching circuit did you use 200pf for the caps. Is 220pf ok for this circuit.??? Can't seem to get 200pf in the UK. Cheers.  |
jordroid
Posted: Wed May 05, 2010 2:17 pm Post subject:
| I don't remember what i did, but i would think that 220pf will be fine. It's a cheapy ceramic strapped across the 20k resistors, and it will probably be a 10% tolerance part anyways. If for some reason it is critical you could put two 100pf caps in parallel but i would just use what you have or can easily and cheaply get. |
adambee7
Posted: Wed May 05, 2010 4:53 pm Post subject:
cheers man  |
adambee7
Posted: Thu Jun 03, 2010 6:00 am Post subject:
Yeah that is a good circuit easy to build on stripboard. Matched up a load of them last week. Going to build the PNP one this week as i've got some filters to build. Well recomended  |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Mon Jun 07, 2010 4:48 pm Post subject:
I'm interested in breadboarding a transistor matcher, anyone got the link to the schematic / build docs? _________________ LektroiD |
adambee7
fifteenrabbits
Posted: Sun Apr 03, 2011 6:21 pm Post subject:
I've decided to build the go-nogo version, however I don't understand the small portion of the diagram that shows the bypass caps.
There are three separate circuits marked "bypass caps"
I just don't know where to put each one.
Thank you so much,
Rabs |
fifteenrabbits
fifteenrabbits
Posted: Mon Apr 04, 2011 6:25 am Post subject:
just to clarify: I don't know where to connect the bypass caps.
If somebody could please take the time to tell me quickly, I'm in a rush as I'm building the synth with a high-school apprentice who only has two weeks left to finish his synth.
Thanks so much! |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Mon Apr 04, 2011 8:29 am Post subject:
The bypass caps are drawn this way to keep the schematic from getting cluttered.
Put the ones at the top center where power enters the circuit.
The ones in the lower right go as close as possible to the IC power pins like C3 and C6 in this schematic:
http://electroschematics.com/wp-content/uploads/2008/10/subsonic-filter-circuit-schematic.gif
If I wasn't at work I could draw a picture or something but I am so I can't. Try googling "bypass capacitor" or "decoupling capacitor" and look at images; you ought to be able to see something that will bring it into focus for you.
Good luck,
Mark |
fifteenrabbits
Posted: Tue Apr 05, 2011 9:45 pm Post subject:
| so the 22uF caps go where the power comes in? |
mark_olson
Posted: Wed Apr 06, 2011 6:25 am Post subject:
| fifteenrabbits wrote: | | so the 22uF caps go where the power comes in? |
Yes. And note that those are electrolytic and that polarity needs to be observed. |
fifteenrabbits
Posted: Wed Apr 06, 2011 6:38 am Post subject:
Thanks Mark!
I have a meeting with my apprentice later today and hope to have the matcher built by then! |
