Sequencer Rate Control
Page 1 of 1 [14 Posts]
Sound Diver
PostPosted: Thu Apr 29, 2010 3:06 am    Post subject: Sequencer Rate Control Reply with quote  Mark this post and the followings unread
Hi All.
would it be possible to add a fine adjust to the rate control of the 16 step sequencer, i'm finding it really difficult to sync the sequencers timing to my other instruments and drum machines, if its not possible to add a fine adjust is there another way around this problem.
jordroid
PostPosted: Thu Apr 29, 2010 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been thinking about this as well, the range of slow to fast speeds is great but it gets a bit tweaky to dial in a tempo in the fastest third of pot travel.
Looking at the schem, the rate adjust pot is just a 1 meg variable resistor, fast speeds occur with the pot adjusted for less resistance, slow speeds with more resistance. Not the classic Ray Wilson voltage divider coarse and fine tuners, like you see on oscillators.
What i am thinking of doing is adding another, smaller value pot wired as a variable resistor in series with the existing 1 meg already there, so that the rate is a product of the total resistance of both pots in series. This will result in a slightly slower slowest speed.
I think that ought to work, but it might take some guesswork to find a value for the fine tuner pot that feels right. If i am missing something obvious and this won't work the way i think it will feel free to shoot it down, i have not tried it and i probably won't for a while.
On another note, to get your sequencer to really sync up with other gear you will need to run them off the same clock source. Barring that an idea i have been toying with recently for using sequencers live with other musicians is to build a tap tempo clock, this thread discusses a tap tempo tremolo, which could probably be used as a clock source with some hacking http://electro-music.com/forum/topic-40981.html and Small Bear electronics sells this chip http://www.smallbearelec.com/Detail.bok?no=795 that might be fun to play with. I think it will be much easier to be able to tap along to keep in time than to constantly adjust the rate control, which is pretty much impossible to keep up for more than a few bars.
yipes, long post, have fun.
RF
Audio files: 28
PostPosted: Thu Apr 29, 2010 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Agreed! Maybe try 100 k?
jordroid wrote:
On another note, to get your sequencer to really sync up with other gear you will need to run them off the same clock source.....
Yep - it's really tough to get two clocks exactly the same....
Either clock your other items with the clock out of the sequencer - or the other way around.
bruce
www.sdiy.org/rfeng
globe town free arts lab
PostPosted: Thu Apr 29, 2010 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a drum machine with a trigger out jack?
I use the trigger out on my tr-626 to step my sequencer
as in this video:
http://www.youtube.com/watch?v=DlQK_II_OBI
You can get irregular step lengths by changing the pattern.
It syncs up perfectly to midi clock when i connect the 626 to my computer.
drew
Sound Diver
PostPosted: Thu Apr 29, 2010 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I HAVE TWO DRUM MACHINES BUT THEY ARE BOTH MIDI AND ALL MY OTHER GEAR IS MIDI TO APART FROM MY DOEPFER SYSTEM I USE WITH THE SEQUENCER.
Sound Diver
PostPosted: Fri Apr 30, 2010 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Would the sugested 100K pot go in between R19/1-2 or R19/3. As my sequencer is still in a working prototype facia, i could try it before i have a finished facia made.
RF
Audio files: 28
PostPosted: Fri Apr 30, 2010 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Just put it in series - either before or after the existing pot.
I was thinking about this, and for fine tune you might try a smaller one than 100k- like 10k or 50k. Experiment a bit and see what feels best to you, and gives the resolution you want.
bruce
www.sdiy.org/rfeng
Sound Diver
PostPosted: Mon May 03, 2010 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Just had an idea (but not being heavily into electronics, it just an idea) would it be possible to use a multi turn pot with a vernier knob for a lot finer rate control. If its possible what size pot?
jordroid
PostPosted: Mon May 03, 2010 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, you could use any type of potentiometer you want and a multi turn would be finer to control, nice idea.
Since none of us has done this yet i would probably swap regular cheap pots in there to determine the desired value, just because multi turns are more expensive and you are less likely to have them lying around or locally available. I think RF's suggested values are a good place to start, i would maybe tend to try the bigger end of the spectrum for multi turns, 100k is 1/10th of 1meg so it will give you about 1/10th the range which sounds about right to me.
If you are counting on this to make it easy to sync up to other gear i still think you will be disappointed, but it may be a worthwhile thing to do anyways.
Excellent looking sequencer by the way, and nice job getting it running!
Sound Diver
PostPosted: Mon May 03, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the response and the posative comments on my sequencer, it ran stright out of the box,
On the rate side what i had in mind was these on the RS.com website.
100k pot RS Stock No. 460-7605
Vernier Dial RS Stock No. 625-1579
What do you think?
jordroid
PostPosted: Wed May 05, 2010 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure what you mean but if i go to rs.com i end up at rocket software? I checked the radio shack site too but the #s you show don't turn up there so i guess that's not what you meant either. Sorry if i'm being dense but i'm not sure where you are looking.
Sound Diver
PostPosted: Wed May 05, 2010 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about that the site is RS Components try
uk.rs-online.com or
rswww.com
could have been worse it could of been a dogging site!!
mikebike
PostPosted: Sun May 09, 2010 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
if youer gonna use a multiturn just replace the 1meg with a 1meg multi.
that should be plenty of fine adjustment
nyd
PostPosted: Tue Jun 08, 2010 6:09 am    Post subject: Use external trigs Reply with quote  Mark this post and the followings unread
I think you're fooling yourself by adding the fine adjust for speed, unless you want to use the Seq16 as your master clock. In your case, where MIDI seems to be the master clock of things I would suggest to trig the sequencer from a drum machine (rim shot out if you have no sync out) or a synth / sampler where you load a simple short sound to trig with.
Pipe the audio from the DM / synth / sampler to one of Ray's attack-release generators, these have schmitt trigger inputs which will be activated by the audio, set the AR to triggered mode, zero attack and a moderately short release, pipe the AR output to ext clock on the Seq16.
