dichotomos
Posted: Tue Apr 13, 2010 7:29 am Post subject:
Curcuit bending 386 and 74HC14B1 chips with a breadboard. |
Hi I figure I might learn a thing or two more from you guys. I've been trying to circuit bend for a couple of months now with limited success. I know from various sources that the older the device is the better it is to circuit bend. I got Nicholas Collins book homemade electronic music and have had better success with building my own creation to bend. Tell me what you think?
http://www.youtube.com/watch?v=cGL7B9lbfng
What other things could I include here to give it more variation in sound textures besides switching out various capacitors and touching open wire leads??? Any advice would be great.
Thanks. |
electri-fire
Joined: Jul 26, 2006 Posts: 536 Location: Dordrecht NL
G2 patch files: 4
Posted: Tue Apr 13, 2010 2:18 pm Post subject:
Re: Curcuit bending 386 and 74HC14B1 chips with a breadboard. |
| dikotomos wrote: | | What other things could I include here to give it more variation in sound textures besides switching out various capacitors and touching open wire leads??? Any advice would be great. |
First advice: post the datasheet of the IC your using so I don't have to look it up myself.
Well, I'm not really mad at you, but hey...
Ok, The 386 is a 0.5W poweramp.
The 74HC14 is a High Speed CMOS Logic Hex Schmitt-Triggered Inverter. An similar and often used CMOS is the **40106.
Googling 40106 oscillator or synt will get you schematics to inspire you. Fun stuff that use it is the WSG , Cacaphonator, and, and, and.
You may want to check out the Lunetta forum. The 40106 is the most used source for Lunetta oscillators. It's the same as the 74HC14, not High Speed, but you don't need that for what you're doing now.
You can use the 74HC14 when you need an external clock for a circuitbent thingy. I "think" SamZen used it to clock an SK-1. |
electri-fire
G2 patch files: 4
Posted: Tue Apr 13, 2010 2:29 pm Post subject:
A couple of potentiometers would give a bit more control than just touch contacts.
Oh, and use up to six 74HC14 outputs, mix them into the 386 amp through 100k resistors or through diodes as discussed in Collins' "Hand Made Music".
And how could I forget, try LED's connected between the outputs.
http://electro-music.com/forum/topic-38634-25.html |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
dichotomos
Posted: Tue Apr 13, 2010 4:15 pm Post subject:
Lots of helpful advice here, One of those sites has a decent Breadboard diagram maker.......I'm all visual right now...so schematics are going to take a while. Last edited by dichotomos on Tue Apr 13, 2010 4:20 pm; edited 1 time in total |
dichotomos
Posted: Tue Apr 13, 2010 4:17 pm Post subject:
I can't really wrap my head around making a schematic just yet so bare with me
this is a mock up of what I made, I started with 221 capacitors on the bottom row but opted to switch them out with some that I found on a board I've been plundering....I don't really know what they are. The 221 capacitor on the top row is going into the ground.
The Big 220uf capacitor is to supposedly boost the signal. My knowledge of all this is almost all hands on and rudimentary at best.
Thanks for the help, I'll try out the potentiometers for sure. Last edited by dichotomos on Tue Apr 13, 2010 4:33 pm; edited 1 time in total |
dichotomos
Posted: Thu Apr 15, 2010 5:28 pm Post subject:
Thanks for the help, I still have a long way to go, the suggestions and the links are informative. I haven't really had the time to school my self properly yet as I'm taking on several things at once to put together for the end term project.
Next time When I post something I'll at least have a link to the proper IC sheet.
Thanks again. |
droffset
electri-fire
G2 patch files: 4
Posted: Sat Apr 17, 2010 6:52 am Post subject:
| droffset wrote: | Don't be discouraged, electri-fire's just grumpy sometimes.  |
Hmyeah, I get into irritable moods easily lately. Sorry. Oh, and welcome to the forum. |
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Tue Apr 20, 2010 6:40 pm Post subject:
| droffset wrote: |
I don't have the Nic Collins book but people seem to like it so maybe try more stuff there too. |
You should check it out! Its a great book full of ideas, chips, and ways to make noise with stuff. Plus it has a great history electronic music woven into it. Collins was an apprentice of gordon mumma so you know its gotta be good. i think he even hung out with david tudor! _________________ home made noise and electronic ill-logic |
synthmonger
electri-fire
G2 patch files: 4
Posted: Mon Jun 14, 2010 11:39 am Post subject:
| synthmonger wrote: | | I thought 7HC*** chips can't handle voltages above 5v (7max)? |
Yep, that's what it sais in the datasheet. |
tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Thu Jun 17, 2010 11:16 am Post subject:
| Quote: | You should check it out! Its a great book full of ideas, chips, and ways to make noise with stuff. Plus it has a great history electronic music woven into it. Collins was an apprentice of gordon mumma so you know its gotta be good. i think he even hung out with david tudor!
Yeah, definately a good read. I really like the way he understand the need to start small and cheap. A couple of well placed sparks is all that's needed to start a good fire. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
