Any reasonably priced 2K tempcos in UK?
Page 1 of 1 [5 Posts]
Mick Bailey
PostPosted: Tue Mar 02, 2010 2:14 pm    Post subject: Any reasonably priced 2K tempcos in UK? Reply with quote  Mark this post and the followings unread
Just looking round to see if anyone knows a reliable source of 2k tempcos in the UK for a reasonable price. If not, is there an easy and cheap substitute to retro-fit into my VCO-1 and XR-VCO? I built them without and they do drift a little bit too much so I'd like to stabilise them.
prgdeltablues
Audio files: 12
PostPosted: Wed Mar 03, 2010 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Farnell have 1k 3000ppm tempcos at £1.01 each:
http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=1174306
As far as I'm aware, you could use two in series to be equivalent to a 2k tempco. Not quite the ideal co-efficient, but better than nothing?
Peter
Mick Bailey
PostPosted: Wed Mar 03, 2010 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peter,
Thanks for the link - should work out ok with some of these. I also intend to relocate my PSU to cut down on temperature rise inside the case.
Mick
magman
PostPosted: Wed Mar 03, 2010 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could also look at using an SMD tempco, like this one:
http://uk.farnell.com/tyco-electronics/lt7330002k0jtg/resistor-temperature-sensing-2k/dp/1174312
Something like what Dave Brown did here:
http://modularsynthesis.com/magicsmoke/mankato/mse.htm
Regards
Magman
forbin
PostPosted: Fri Mar 19, 2010 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm by the time they get to Australian Farnell the price has gone from 1 pound to $6.50AU!!! the current exchange rate it should be $1.60... postage and storage must be a bit expensive over here...
