Coming up on Radio 1 at
Wall wart power supply - 15V instead of 12V?
Page 1 of 1 [5 Posts]
oscillate_wildly
PostPosted: Fri Feb 26, 2010 5:17 pm    Post subject: Wall wart power supply - 15V instead of 12V? Reply with quote  Mark this post and the followings unread
I just finished putting together a strip board version of the MFOS Wall Wart power supply.
I'm using the L7812 and L7912. Both are heat sinked.
I am also using a 12VAC 1000mA wall wart.
When measuring the voltage, I'm getting the readings:
15.86V and -15.86V
I was hoping to get the readings 12V and -12V, as I am using it to power a Soundlab plus and the 1V/oct keyboard.
Does anyone know how I can reduce the voltage to the desired 12V and -12V?
(I'm putting the black lead of the multimeter on the negative terminal and the red lead on the positive terminal)
Thanks.
RF
Audio files: 28
PostPosted: Fri Feb 26, 2010 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you post a pic of your circuit? Sounds like you may have something wired wrong...or those regulators are 7815 and 7915's
bruce
www.sdiy.org/rfeng
oscillate_wildly
PostPosted: Fri Feb 26, 2010 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply!
I double checked the regulators, they are definitely 7812 and 7912.
On double checking, I think i may need to switch the regulators with each other.
Last edited by oscillate_wildly on Fri Feb 26, 2010 6:57 pm; edited 2 times in total
oscillate_wildly
PostPosted: Fri Feb 26, 2010 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Switched them around, and now I'm getting 11.8V and -12V.
Problem solved!
RF
Audio files: 28
PostPosted: Fri Feb 26, 2010 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers
Glad to hear it!
bruce
www.sdiy.org/rfeng
