help - no sound out whith minilab
Page 1 of 1 [17 Posts]
MindControl
PostPosted: Fri Aug 21, 2009 4:12 am    Post subject: help - no sound out whith minilab Reply with quote  Mark this post and the followings unread
I finally finished mini-soundlab and I'm not getting any sound out of it all, so far? Its the basic minilab without any modifications.
I'm confident whith my soldering, but I may have misswired it somehow?
This is where I'm at, Iv got the SH101's CV out and Gate out connected to minilabs CV in and Gate in. Though, I am using 3.5 to 6.5 plug adaptors.
And the minilab's audio output is sent to my stereo amp.
I can't feel any heat on any of the IC's or transistors, I'm wondering whether if minilab is receiving any control voltage in the first place.
I guess I will have to spend a bit of time finding a better setup to test it.
Any suggestion's out there that could help in diagnosing the problem?
MindControl
PostPosted: Sat Aug 22, 2009 12:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I managed to get the circuit alive, something strange about the jacks?
There is sound there, but very faint. Some of the knobs appear to do things and some of the functions appear that they might work. Nothing from the main 2 oscillators. The CV and gate in sockets appear to work from the sh101 as well from trigger button. It sought of sounds a bit like very faint radio static so far. Crying or Very sad
I was wondering whether soundlab output is supposed to be standard line out or does it need to be connected to a preamp?
I think this project might turn out to need long term diagnosing so far? Only things I could see that I might get wrong might be a, resister, dry solder joint or a panel wire. Besides checking wiring and everything, I think I might have to realy study the circuit diagrams too.
MindControl
PostPosted: Sat Aug 22, 2009 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm finally getting something now Very Happy Not sure if its working properly, it sounds radio frequency or circuitbent. I forgot to put the jumper leads in to bypass the 1 volt mod.
All oscillators work except for the noise I think. Filter works and most of the switches do something. Its hard to tell whith the modulation whith the sound being in the high frequency and treble region. I still think it needs preamplification so far?
At least something is happening now Very Happy
MindControl
PostPosted: Sat Aug 22, 2009 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Still playing whith it now and not totaly sure if it is working properly, but I'm getting quite a few different sounds out of it. It might sound better through smaller speakers than my 15 in hifi boxes cause a lot of it is coming out of the tweeters I think. I'm using a small beringer tube preamp to bring it up to line level. The apegiator of sh101 is controlling the oscillator and I can adjust its speed on the sh101 too. Very scifi or detective movie indeed. Very Happy
RF
Audio files: 28
PostPosted: Sat Aug 22, 2009 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi - You should not have to use a pre-amp for that. I think the outputs are pretty 'hot'.
Have you checked to make sure the output jacks are all wired correctly? It's easy to make a mistake there and run the ouput to the ground lug on the jack.
These are fun instruments - can't wait to hear some sounds and see some pics from yours.
bruce
www.sdiy.org/rfeng
MindControl
PostPosted: Sat Aug 22, 2009 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bruce,
The first thing I found I had to do was re-wire the jacks and so audio out and CV sockets are all functioning now. I double checked jacks whith multimeter.
I'm finding that I'm needing greater than 40db gain to get the audio up to standard audio line in. That amount of gain is what you might find in most preamps?
I thought that the sound was a little high frequency or trebly, not as full as one might expect. Maybe most of the sound is being filtered out by wrong component value? Basically its fairly direct from the chip via pot. Like most audio devices, they don't like ouput pot right on full, as opposed to three quarters. There is no background noise whith the sound, and even whith preamplification?
Iv noticed that there are a few prebuilt minilab's for sale whith different configurations in metal and plastic boxes. If they have added a preamp I suppose it would drain the battery quicker, if they had room to fit it in?
I'm just going to have to check all components and circuit diagram I suppose? Besides that issue, it seem to be working properly as one would expect?
PostPosted: Sun Aug 23, 2009 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
You should be getting at least 2-5V p-p output which is way louder than any line level, there's no way you would a pre-amp for it if it's working properly.
MindControl
PostPosted: Sun Aug 23, 2009 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
O/K mmmmm Question
MindControl
PostPosted: Mon Aug 24, 2009 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I checked all resistors on board and did have to replace R80 whith the correct value of 20k from 100k, and that did have an effect. All other resistors appear to be correct and all wiring appears to be O/K too.
I think my soldering was good in that all transistors should be working, and all diodes and capacitors in right orientation.
But, still very weak output from the VCA LM13700. Also, I'm not sure if the band pass? is working correctly on the VCF? And the noise generator is there but not really pronounced. You can sought of tell its there when you turn the filter resonance knob right up.
I'm checking it over, reading and thinking? I should be learning something atleast. Smile
anyway?
PostPosted: Mon Aug 24, 2009 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
A couple of things,
Have you got a scope?
A multimeter?
The next thing I'd check is that you have the right voltages on all the power pins of the ICs.
Then I'd be looking at signal levels before and after the mixer, VCF, and VCA stages.
That should shed some light on the problem area.
MindControl
PostPosted: Tue Aug 25, 2009 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Uncle Krunkus
I don't have a scope, only the multimeter.
I'm getting full strength signal whith osc1, osc2, noise, LFO, mixer, before VCF and VCA, as one should expect now. Very Happy
Filter appears to be working fine.
Still weak signal after VCA Crying or Very sad
Voltages on both LM13700 and rail were -7 and +7.10. Battery's were fresh, but I think the voltage is dropping a little.
This hex inverter is it powered, I don't know what pins if it is?
PostPosted: Tue Aug 25, 2009 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, the 40106 hex inverter will be ground on pin 7 and +V on pin 14.
PostPosted: Tue Aug 25, 2009 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the original SoundLab isn't it? Not the Plus or the Ultimate.
MindControl
PostPosted: Wed Aug 26, 2009 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the original soundlab whith no mods.
I have not looked at it today. Not really many components in that area. Might be a dry joint or a simple wiring thing?
The circuit is obvioulsy modulating, filtering, the switches and knobs all have effect?
I must say the internet is not too good at the moment for browsing web pages.
MindControl
PostPosted: Thu Aug 27, 2009 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
ahhhh figured it out, just a bad solder joint pin 16 of the IC.
So she is up and running now, and I can recommend this project. Very Happy
This is like the sound of a modular in a little box, all that beautiful modulation. Very Happy
PostPosted: Thu Aug 27, 2009 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! Very Happy
Audio files: 373
PostPosted: Thu Sep 03, 2009 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hehe - reading this thread (sorry I didn't read it until now) felt like Déjà vu. You pretty much mirrored my progress when I made the SoundLab - first no sound at all, tweak tweak, then a little faint weird sound, tweak check values against spec desolder solder x 10, more and more things start to fall in place, tweak worry tweak, it's there! Very Happy
Krunkus tip about a scope and checking ICs is great, BTW (for anyone else having these problems). Ray has a great checklist for what signals should be on different pins and panel connections, and that helped me immensely after I got the scope.
/Stefan
