suggest an amp to use with the WSG
Page 1 of 1 [5 Posts]
sndbyte
PostPosted: Mon Jul 27, 2009 2:44 pm    Post subject: suggest an amp to use with the WSG Reply with quote  Mark this post and the followings unread
I've been having a lot of fun with my WSG but I've primarily been using it with headphones.
I have used it with a small portable amp (one of those battery operated Fender Mini Twin Amps) but I'm not happy with the sound. When using my amp the sound seems really distortated... maybe even muddy.
But when I plug my headphones directly into the WSG I get a much cleaner sound. The volume is realatively low but the sound quality is much better.
So I was wondering what type of amps people would suggest I use with the WSG? It should be small since I live in an apartment. I imagine the Fender wasn't a very good choice since it was designed for guitar players.
Or perhaps I should build a small amp. Are there any good designs or kits available on the internet?
thanks,
Chris
mark_olson
PostPosted: Mon Jul 27, 2009 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
My WSG sounds great through an old Peavey KB15 keyboard amp I picked up second hand really cheap. And modest though it is, it is more than loud enough to disturb the neighbors. Of course the more amp you can get the more impressive it will sound Smile You won't be sorry if you get an amp with reverb too.
Mark
fluxmonkey
PostPosted: Tue Jul 28, 2009 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Guitar amps are designed to add distortion. I build bench-top amps around the LM386 chip, like this:
Posted Image
or a cheap stereo amp from th thriftstore....
www.fluxmonkey.com
richardc64
Audio files: 26
PostPosted: Tue Jul 28, 2009 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
...or a small PC amp and spkrs, also from a thriftstore.
Wizard Mike
PostPosted: Thu Jul 30, 2009 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Personally I like the roland cube cm-30. It's a small keyboard amp with multiple inputs and on board mixer so you can hook up different noise toys all at once. It also makes a great workbench amp due to it's small foot print. I pick one up used for about 50USD.
http://www.roland.com/products/en/CM-30/index.html
