question about grounding the WSG
Page 1 of 1 [3 Posts]
sndbyte
PostPosted: Wed Jul 22, 2009 7:29 pm    Post subject: question about grounding the WSG Reply with quote  Mark this post and the followings unread
I recently built a Weird Sound Generator and have a question about grounding.
Rather than bolt the ground wire to the aluminum panel, I just attached a sort of flat like ring connector to the ground wire that I then slip over one of the 4 screws that hold the panel to the case. When I attach the panel to the case the screw is tightened and the flat ring connector (ground) is sandwiched between the aluminum panel and the wood case.
So I am wondering, is this an effective way to ground the WSG?
I decided to try and test if this method was working. So I played the WSG with the ground attached, then played the WSG with the ground not attached to the panel. The funny thing was that I couldn't detect any difference in the sound. This leads me to my 2nd question... does an ungrounded WSG sound any different?
Thanks for any input in advance!
Chris
ps: I posted a picture of my WSG in the DIY forum:
http://electro-music.com/forum/topic-31618-150.html
slacker
PostPosted: Thu Jul 23, 2009 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Depending on what sort of output jack you've used the panel will probably already be grounded through that. On a lot of jacks the threaded metal part that the nut attaches to is connected to the sleeve connection, so screwing the jack to a metal panel will automatically ground the panel.
If your jack isn't like that then the way you've grounded it is fine.
Grounding the panel can help to stop interference but a lot of the time you won't hear much if any difference if it's not grounded.
sndbyte
PostPosted: Sat Jul 25, 2009 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info!
