WSG volume problem
Page 1 of 1 [5 Posts]
birdleisure
PostPosted: Mon Jul 20, 2009 4:53 pm    Post subject: WSG volume problem
Subject description: volume too low
I am new to this board and new to this sort of project. I have just completed a WSG kit and everything seems to be working fine. The only issue I am having is that the volume is really low.
Plugged into a 50 watt amp (at 3/4 volume) it is about as loud as a fan. When i touch various connections (potentiometer or switches) the particular sound gets louder and but the other voice remains quiet and other functionality remains quiet.
Do you have any suggestions on a remedy? I assume I am just not doing something right. Let me know if I should give any more information.
thanks
steve
Danno Gee Ray
PostPosted: Mon Jul 20, 2009 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check your ground paths. I believe this behavior has, in the past, been found to be a missing ground connection or two.
birdleisure
PostPosted: Mon Jul 20, 2009 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply. I checked all wiring and everything seems to be in place. I am not sure what else to do.
steve
birdleisure
PostPosted: Tue Jul 21, 2009 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
just in case anyone is as confused as i am...it turns out the output jack was bent just enough to make a connection but it was really weak. I bent it slightly inward and problem is fixed.
Danno Gee Ray
PostPosted: Tue Jul 21, 2009 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well done! Glad it's working.
It's a fun instrument.
