Silvered Mica or Polystyrene Cap for VCO
Page 1 of 1 [6 Posts]
eventi
PostPosted: Thu Jun 25, 2009 7:24 am    Post subject: Silvered Mica or Polystyrene Cap for VCO
Subject description: Can I replace with a differnet type?
I don't know from capacitors, but I'm getting my parts order together for my first VCO, and I need a Silvered Mica or Polystyrene Cap for C6 in this schematic: http://musicfromouterspace.com/analogsynth/VCO200604REV01/vcoschematicpage1.gif
How important is the capacitor type? I can find other types in that value, just not silvered mica or polystyrene
druish
PostPosted: Thu Jun 25, 2009 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Siver mica and polystyrene have very good temp stability. ie. capacitance changes little with temp changes. So you would use these in a circuit where the capacitance is critical to the circuits behavior (like in an oscillator).
Certain cap material is better depending on the application.
polystyrene and silver mica have good temp stability
ceramics are cheap but good in non critical circuits and distortion effects
most audiophiles like polypropylene or polyester film because they are smooth sounding and reliable.
people go nuts over caps but i've learned that you should always go the most economical unless the effect you are looking for calls for a better cap.
eventi
PostPosted: Thu Jun 25, 2009 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks druish -
Can I use a polypropyleme or polyester instead of the mica? Do they have the same temperature stability? I really don't get what that cap does in the schematic I linked - some sort of cleaning of the raw wave, i guess
druish
PostPosted: Thu Jun 25, 2009 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
No, you should use the polystyrene or silver mica in that part of the circuit. It affects the frequency of the oscillator.
eventi
PostPosted: Thu Jun 25, 2009 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the help
diablojoy
PostPosted: Fri Jun 26, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
rush on line www.rush-on-line.co.uk/cap_forums.html
they have the cheapest silver mica and polystyrene caps
available that i can find
good to deal with and no mininum
also they have good low tolerance values
go for f or even better d values if in stock
great for VCO's and Sample/hold ccts
