My first synth - Pots wiring
Page 1 of 1 [5 Posts]
Jimmydoodaa
PostPosted: Sun Jun 14, 2009 5:44 am    Post subject:  My first synth - Pots wiring
Subject description: Andrew Sharp's strip-board layout - please help!
Hi all,
Just finished wiring up Andrew Sharp's strip-board layout to realize I haven't got the faintest idea how to wire up the pots.
... any of them!!
http://www.musicfromouterspace.com/analogsynth/YOUR_FIRST_SYNTH/YOUR_FIRST_SYNTH.html#STRIPBOARD
I've scoured the wsg website, and musicfromouterspace... .lots of differrent schematics, totally utterly confused.
Please help.... I'm so close.
RF
Audio files: 28
PostPosted: Sun Jun 14, 2009 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Not so tough Smile
The "arrow" of the pot is the wiper - that's the center of the three terminals.
It doesn't matter as far as function of the circuit which of the outside terminals go to which wire - although one way may be more intuitive to the operator.
Good luck!
bruce
www.sdiy.org/rfeng
Jimmydoodaa
PostPosted: Sun Jun 14, 2009 9:44 am    Post subject: ta
Subject description: yes.. but.... erm....
Ta for the reply Bruce.
So... when wiring 2 wires to a pot, one in the middle, the other doesn't matter too much ( I guess it depends which way you want to turn it) ?
..however, some on the strip-board layout from Andrew Sharp's layout have 3 wires...
Also, looking at the PCB layout on the site, most of the pots are connected from all 3 points.
Can you tell I'm not an electrician? .. I'm still confused.
Thanks.... and sorry.
RF
Audio files: 28
PostPosted: Sun Jun 14, 2009 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the same if all three terminals are connected. The 'wiper' is the one that is critical to it operating correctly. The other two just determine, for example - which way you turn it to increase the volume.
www.sdiy.org/rfeng
Jimmydoodaa
PostPosted: Sun Jun 14, 2009 4:07 pm    Post subject: pots pots pots
Subject description: how?
thanks so much for your help. I'll give it a go and report back. I suspect it's my brain that's wired wrong and not my pots.
