A30N
Joined: May 06, 2009 Posts: 44 Location: Southampton, England
Posted: Sun May 17, 2009 8:15 am Post subject:
Ordering parts - Need some help |
Sorry to keep chucking loads of questions @ you guys, but this is my first synth im building and i really wanna get it right
Im ordering some parts and stuck on a few areas if you don't mind helping me out
Im stuck on a few parts:
Sound Lab:
C3 Tantalum Capacitor 2uf.... What voltage 10/16/25 v?
I cant get all the 1/4 watt resistors @ 1% should i just go for the 5% or try and use as many 1% i can get combined with 5%. Or can i use .4 watt?
I cant find the hex inverter cd40106 what hex inverter could i use instead?
Sample and Hold:
I have noticed on peoples front panels that their sample and hold has 2 pots "rate" and "output" but i can only see 1 pot in the parts which is R4 Potentiometer 1M and this is for sample rate. Where is the pot for output and do i need any other components?
Sound Lab Mini-Synth Intra-VCO Modulation:
I cant find any non-electrolytic caps @ 2uf but can find 2200pf one, can this be used?
Fine Tuner circuit:
ant find any 50k pots - can i use a 47k?
VCO V/Oct Scale Adjustment Modification:
Is this worth doing? i dont intend to play the synth live, more recording down and chucking in a sampler.
I see the 2K PT146 are hard to find in the uk, is it worth the hassle?
Thanks,
Jamie |
LetterBeacon
Posted: Sun May 17, 2009 8:43 am Post subject:
Re: Ordering parts - Need some help |
| A30N wrote: | Hi,
Sound Lab:
C3 Tantalum Capacitor 2uf.... What voltage 10/16/25 v? |
The voltage rating should be higher than the voltage you are running your circuit on. The Soundlab is +/- 9v so I'd probably use either 16v or 25v
| Quote: | | I cant get all the 1/4 watt resistors @ 1% should i just go for the 5% or try and use as many 1% i can get combined with 5%. Or can i use .4 watt? |
Which ones did you have a problem finding? I seem to remember fairly common values needed?
| Quote: | | I cant find the hex inverter cd40106 what hex inverter could i use instead? |
Looks like Maplin have finished stocking the CD40106. They do a HEF40106 here. I'm pretty sure you can use can use that. Rapid also do one.
| Quote: |
I cant find any non-electrolytic caps @ 2uf but can find 2200pf one, can this be used? |
2.2uf should be fine.
| Quote: |
Fine Tuner circuit:
ant find any 50k pots - can i use a 47k? |
Yep. |
A30N
Posted: Sun May 17, 2009 9:03 am Post subject:
Hi LetterBeacon,
Thanks for taking the time to help me out.
The resistors im having trouble finding from Rapid are:
1/4 watt 1% - 39k, 47k and 100k which is sold out.
I can find them @ RS but they want me to buy them in packs of 5 with a subtotal of £12
Also i can only find a 2.2uf Tantalum Capacitor (c3 ) instead of a 2uf will this be ok?
Jamie |
LetterBeacon
Posted: Sun May 17, 2009 10:17 am Post subject:
No problem.
Rapid have them in packs of 100 @ £0.95 each:
39K = 62-0937
47K = 62-0942
100K = 62-0964
I know buying 100 seems like over-kill but those values crop up a lot in SDIY, especially 100K.
Yep, 2.2uf tantalum should be fine too. |
A30N
Posted: Mon May 18, 2009 12:33 pm Post subject:
| LetterBeacon wrote: | No problem.
39K = 62-0937
47K = 62-0942
100K = 62-0964
Cheers LetterBeacon  |
