soundlab CV question
Page 1 of 1 [4 Posts]
adhmzaiusz
PostPosted: Sat May 09, 2009 11:47 pm    Post subject: soundlab CV question Reply with quote  Mark this post and the followings unread
Hi, im about 98% done my soundlab circuitry and wiring, pretty much everything is working at the moment but a switch i melted with my soldering iron. Anyway aside from that, I tried plugging in a sh101 to control the freq of both osc and notice they both work individually, but I was under the assumption that vco 2 will pick up and slave to cv vco 1 input if there is nothing in input2. Is something wrong with my wiring or am i just dreaming here?
Audio files: 163
PostPosted: Sun May 10, 2009 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, you can either link them permenantly with a bit of wire or if you are using 1/4" jack sockets wire those to link vco 2 to vco 1 cv inputs until plugging a jack in vco 2 breaks the feed from vco 1 , or even use a toggle switch .
David
adhmzaiusz
PostPosted: Sun May 10, 2009 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
David
Is linking them as easy as putting a wire between them? I thought they were already linked? Which contact do i link, the tip contact? thanks!
Audio files: 163
PostPosted: Mon May 11, 2009 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had a quick squint at the plans again , vco 1 & 2 have seperate c.v. inputs via a 100K res. each . pop a switch in to couple them or if you use these sockets wire them to form a normally on switch on the vco 2 cv input.
 Filesize:  6.92 KB
 Viewed:  2508 Time(s)
