Varisample
Page 1 of 1 [4 Posts]
Audio files: 373
PostPosted: Mon Jan 26, 2009 1:13 pm    Post subject: Varisample
Subject description: multiple sample variations in a single file
Was idly browsing through stuff bundled with Live yesterday, when I came across a sample called "Drum Machines 909", which seemed to be a bunch of similar samples in a single .aif file, playing one after each other. I immediately thought of how I've tried recording banging on a can or an egg or something, and then stored it in a single file so that I could choose which of the samples that I wanted or liked when I used them later - it's such a pain to record many samples one by one, storing them in separate files.
It isn't that easy... the interfaces for scrolling through a sample like that a often cumbersome. I've had some success on an ESX, but when the files get bigger the start position knobs are a bit too low resolution.
A couple of minutes later it struck me - I have this ChucK thing, that is a programming language. Those are pretty good at doing stuff automatically, and ChucK is really good at audio. Why don't I just make an app that looks through a sample, finds all of the hits and lets me play them in some easy fashion.
So I wrote this Varisample thing. It's a class containing a LiSa that is loaded with a sample file, and some functions for playing the different variations. I've included some documentation at the top of the file. I'm including a little package with some test code and recordings of me clapping and banging on two different cans - run "test_varisample.ck" to listen to it. It isn't the greatest demo, but I think it sounds a little bit more lively than static, single samples.
I have a hunch that this is done in Ableton somewhere (since I found that file), but I can't guess where. Anyway, what do you think? Useful?
Stuff left to do: sounds with slow attack cut in too sharply because of the simple threshold algorithm I use when looking for sound. Any thoughts on a better (but still simple enough) way? Also, I wanted to pan sounds when using multiple voices, but there is no pan function per voice in LiSa. What's the easiest way to do that - I am guessing that I need two LiSas, one for left and one for right.
/Stefan
Edit: new version of the Varisample class and a second test bundle
Varisample test.zip
Varisample test bundle
 Filename:  Varisample test.zip
 Filesize:  2.05 MB
 Downloaded:  426 Time(s)
Varisample.ck
Varisample class version 2, with docs
 Filename:  Varisample.ck
 Filesize:  6.38 KB
 Downloaded:  471 Time(s)
Varisample test2.zip
Better demonstrates the sound variations
 Filename:  Varisample test2.zip
 Filesize:  1.55 MB
 Downloaded:  422 Time(s)
Audio files: 373
PostPosted: Tue Jan 27, 2009 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Should I detect the lack of responses as this is tired old thing that everyone knew about, or does the code not work? Wink
Anyway, I fixed the attack thingie, and attached a new bundle that better demonstrates the variation in sound.
/Stefan
rogan
PostPosted: Tue Jan 27, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The lack of response for me is being busy, but I plan to check this out when things calm down. Finding attacks on the fly is *very* interesting and, I would guess, a very challenging problem in general.
Audio files: 373
PostPosted: Wed Jan 28, 2009 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks for saying something Smile It has been a bit quiet here in the forums lately.
I think the attack detector could probably be perfected a bit more, and maybe needs to be tweaked for some samples, but my own tests were pretty satisfactory.
/Stefan
