Nord 2 rack splits??
Page 1 of 1 [13 Posts]
DrLoK
PostPosted: Wed Jan 21, 2009 1:19 pm    Post subject: Nord 2 rack splits?? Reply with quote  Mark this post and the followings unread
Hello all. Just purchased a nord 2 rack. I was wondering if I am going to be able to split and layer sounds on my axiom 61 controller the same as the keyboard versions. Thanks.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome DrLoK
In short: no, you can't, despite your new president...
I don't have a rack version, so I use the keyboard tool in CuBase, set both Slots to the same Midi Channel and in Split mode the Slots use the complete range, so you have to use different Midi channels to get some results, which means your controller must have a Midi Split function.
To make it complete, where the rack version has its Trigger button the Keyboard version has its Keyboard Split button...
Don't be disappointed... Wink
Wout
PS and BTW and Note: layering sounds can be easily done, but read the sticky thread about Midi and Rack!
DrLoK
PostPosted: Wed Jan 21, 2009 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info. This is soooo not cool. Looks like I will be eBaying so I can get the board... Rolling Eyes Always something
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
... which means your controller must have a Midi Split function. ...
Well, I don't have an Axiom 61 either, but
the specifications of this controller wrote:
4 independent configurable keyboard zones
which means three split points IMHO Very Happy
What, that means you can use all four Slots in a four zone configuration...
And by using just one Midi cable!
Unfortunately you only have three hands, counting your nose too Wink
Wout
DrLoK
PostPosted: Wed Jan 21, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
?? so what your saying is in effect it is still possible to split the zones with my controller? i.e. slot A on 14 keys or so Slot B on 14 keys or so and so on? Would I stll be able to layer?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
If M-Audio means with 'zones' the same as other synth and controller manufactories mean by it...
Normally you can set which keys are active in a zone (sometimes they can overlap each other) and you can set which Midi channel is to be used by each zone. Each zone controls another Slot. The Keyboard Shift of the NR2 can also be used.
Man, it's so cooooooooooooooooooooooooooooooooooo-ol Wink
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
DrLoK wrote:
... Would I stll be able to layer?
You are always able to play a layer! But read the sticky thread first!!!!
Just for the right understanding: Layers and Keyboard Split have nothing to do withg each other...
Wout
DrLoK
PostPosted: Wed Jan 21, 2009 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I meant was when I seen a demo the guy had two sounds playing on one key. Is this still possible with the rack. So for example I could have slots A and B sound of choice on half of my controller and slots C and D sounds of choice on the other half of the controller? Correct me if I'm wrong on that concept. I thought that what is done on the keyboard versions.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, we can Very Happy
Two Programs (Program is a sound) in Slot A and B, maybe Midi channel 1.
Also two Programs in Slot C and D, using Midi channel 2.
Then on the Axiom 61 create two Zones using Midi channel 1 and 2 repectively.
Better save such a stetting in the NR2 as a Performance.
A Layer is a sound using more then one Slot and is controlled by just one Zone, mostly the complete controller keyboard. The Hammond emulations in Performance mode are nice examples.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Again, before starting to experiment with layers, read
http://electro-music.com/forum/topic-30652.html
Wout
DrLoK
PostPosted: Wed Jan 21, 2009 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. Thank you for clarifying all of that for me. Now all I need is one of those studiologic vmk 188 junks... Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 21, 2009 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
DrLoK wrote:
... studiologic vmk 188 junks... Smile
Well, how do I tell you this... You're sitting down? Yes?
I think that Studiologic thingy doesn't have the ability to create zones...
http://www.studiologic.net/manuals-fatar/wmk149-188_manual.pdf
Shhh! Don't spread the word...
Wink
Just stick to your Axiom!
Wout
DrLoK
PostPosted: Wed Jan 21, 2009 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
LOL. Ain't that some shit. How can they call this a professional controller without zone capability? Rolling Eyes Like I said...Always something.
