radarsat1
Posted: Thu Sep 18, 2008 2:21 pm Post subject:
this might be a good opportunity to mention something that i posted to the mailing list quite a long time ago but got few responses..
https://lists.cs.princeton.edu/pipermail/chuck-users/2007-August/001924.html
I'll just repost the text here:
| Quote: | I've been making a few Chuck synths lately and have been wanting a way
to play them straight from the keyboard instead of having to attach a
MIDI device. I used to do this all the time with FastTracker back in
the DOS-ages.
Anyways, of course Chuck can get keyboard input, so all that was
missing was a mapping from the keyboard keys to MIDI note numbers.
Attached is a Chuck script that reads the keyboard and then generates
Events containing a note number. These are available through a public
class, so a separate Chuck script can wait for the events and spork
notes.
Note that it's not quite an up-to-scratch implementation of polyphony,
since there is only a single event structure that will get overwritten
by the next key press. Maybe I'll work on that next... (perhaps using
an array to store extra notes, but some timing calculations will need
to be made..)
Oh yes, and this is designed for a US keyboard, but feel free to
change the keymap. I figured it out from the kb.ck output.
So anyways, enjoy.
ps., run concurrently:
$ chuck kbpiano.ck kbpiano_example.ck
kbpiano.ck:
| Code: |
// Script which maps keyboard events into piano keys, allowing you to
// play melodies on the computer keyboard, tracker-style.
// Works for US keyboards only, however the keymap can be easily changed.
// (Generated by examining output from Chuck's kb.ck example file.)
// This may need some work to support polyphony properly. Specifically,
// the single Event will need an array of notes, and timing will have to
// be measured to detect chords.
// - Radarsat-1, 2007
// radarsat1@gmail.com
KBHit kb;
false => int verbose;
5 => int octave;
class KeyEvent extends Event
int note;
float freq;
string notename;
int octave;
public class kbpiano
static KeyEvent@ evt;
KeyEvent kevt @=> kbpiano.evt;
// Unused, but good for reference -- upper keyboard octave keycodes
[113, 50, 119, 51, 101, 114, 53, 116, 54, 121, 55, 117, 105, 57, 111,
48, 112, 91, 61, 93] @=> int upper[];
// Unused, but good for reference -- lower keyboard octave keycodes
[122, 115, 120, 100, 99, 118, 103, 98, 104, 110, 106, 109, 44, 108,
46, 59, 47] @=> int lower[];
[27, 91, 65] @=> int octup[]; // Cursor up
[27, 91, 66] @=> int octdown[]; // Cursor down
["C","C#","D","D#","E","F","F#","G","G#","A","A#","B"] @=> string notes[];
[-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,
-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 12, -1, 14, 16, 27, -1, 13,
15, -1, 18, 20, 22, -1, 25, -1, 15, -1, 30, -1, -1, -1, -1, -1, -1,
-1, -1, -1, -1, -1, -1, 29, -1, 31, -1, -1, -1, -1, 7, 4, 3, 16, -1,
6, 8, 24, 10, -1, 13, 11, 9, 26, 28, 12, 17, 1, 19, 23, 5, 14, 2, 21,
0, -1, -1, -1, -1, -1] @=> int keymap[];
fun void handle_octave()
kb => now;
kb.getchar() => int char;
if ((char == octup[1]) || (char == octdown[1])) {
kb => now;
kb.getchar() => char;
if (char == octup[2])
octave+1 => octave;
if (octave > 8) 8 => octave;
else if ((char == octdown[2]))
octave-1 => octave;
if (octave < 0) 0 => octave;
if (verbose)
<<<"Octave:",octave>>>;
while (true)
kb => now;
while (kb.more())
if ((char == octup[0]) || (char == octdown[0])) {
handle_octave();
else {
keymap[char] => int note;
if (note >= 0) {
if (verbose)
<<<notes[note%12],octave>>>;
note + (octave*12) => kevt.note;
octave => kevt.octave;
notes[note%12] => kevt.notename;
Math.mtof(kevt.note) => kevt.freq;
kevt.broadcast();
kbpiano_example.ck:
| Code: |
// Example of using the kbpiano.ck script to map the computer keyboard
// to a piano, tracker-style.
<<<"Press keys on your keyboard to play the piano.\nUp and down cursor keys change octave.\n(US keyboards only, sorry.. feel free to edit the keymap!)">>>;
fun void mandolpluck(float freq)
Mandolin mand => dac;
freq => mand.freq;
mand.noteOn(1);
3::second => now;
while (true)
kbpiano.evt => now;
<<<kbpiano.evt.note, kbpiano.evt.notename,
kbpiano.evt.octave, kbpiano.evt.freq>>>;
spork ~ mandolpluck(kbpiano.evt.freq);
