Help Combining Software
Page 1 of 1 [2 Posts]
LandOfDoAsYouPlease
PostPosted: Thu Jul 24, 2008 10:49 pm    Post subject: Help Combining Software Reply with quote  Mark this post and the followings unread
Im working on my macbook, and Im fairly new to MIDI so I have a few questions.
I have Reason, Reaktor, Logic Pro, and Ableton Live.
How do I efficiently combine all of these into one functioning "unit" persay, so that I can use all of them and record all of them at the same time?
Thanks,
LODAYP
I HEAR you and YOUR BAND are SELLING your GUITARS and BUYING TURNTABLES.
I HEAR you and YOUR BAND are SELLING your TURNTABLES and BUYING GUITARS.
They Put Angels In the Electric Chair.
Audio files: 373
PostPosted: Fri Jul 25, 2008 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
With multiple softsynth setups becoming more common, it's curious that this isn't better supported by sound interface manufacturers or even the OS.
A start for the multiple DAW + reactor thing would be to start up IAC Driver (do a search on IAC driver here, Acoustic Interloper has made a post somewhere). Then decide which of your programs should be the tempo master, and configure it so it sends MIDI synch to the IAC driver. Configure the others to recieve MIDI sync from IAC driver.
Then, if you want to record everything into a single DAW, download Jack OSX and set up an audio channel there. Configure the recording DAW to record from Jack OSX, and the others to send their audio to Jack OSX.
/Stefan
