Novation X-Station 25 functioning.
Page 1 of 1 [3 Posts]
marginal
PostPosted: Wed Jul 16, 2008 5:49 pm    Post subject:  Novation X-Station 25 functioning.
Subject description: Basic functions of the X-Station 25
Hello.
Please help a newbie.
I am sorry to bother you with my (probably stupid) questions, but would like to make my X-Station work.
My question for now is:
Why there are no voices below 100 under the SYNTH PROG menu (I only have voices from 100 to 299) and why aren't there (or where do I find) acoustic voices?
Any help will be greatly appreciated.
Kind regards.
My X-Station
 Filesize:  14.36 KB
 Viewed:  5690 Time(s)
dj-mike666
PostPosted: Mon Aug 18, 2008 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
You can go to:
http://www.novationmusic.com/support/soundbanks/xstation/
There are for download the Factory Sounds plus 100 new sounds updates. There are also clear instructions on how to upload the soundbanks to the X-Station. You need to keep in mind that the X-Station stores the soundbanks in 2 different memory modules each holding 100 presets. If you upload in the module the Factory sounds and then update the 100 new sounds you will lose half of the Factory sounds from the memory module in which the 100 new sounds will be stored.
I hope the answer helps.
marginal
PostPosted: Mon Aug 18, 2008 10:40 am    Post subject: Thanks. Reply with quote  Mark this post and the followings unread
Thank you very much.
