My New Bends
Page 1 of 1 [4 Posts]
imaguitargod
PostPosted: Sat Jun 14, 2008 10:44 am    Post subject: My New Bends
Subject description: Why doesn't this one work right?
Well, I’ve just finished up my new instruments, aptly named “High on Speed” and “Distorted-o-board”, for my noise shows. Here’s me as the Mad Scientist getting ready to go to work.
Posted Image
This is the High On Speed opened at the start of the project.
Posted Image
I ended up crossing two areas of the circuit board on a children’s electronic book strip and connecting them to an on/off mini toggle switch. One switch causes the thing to cycle through all of it’s sound effects. The other switch causes the thing to play the sound at 4x faster than normal which really gives it more of a cartoony sound than usual. Here it is all built with an output.
Posted Image
Now here’s where I discovered a problem that I don’t understand why it’s doing what it’s doing. It’ll only play through the on board speak if there’s a input going into the output jack that I wired on. When I connect the output jack to a small, 9v battery operated speaker, it plays through that speaker. If I connect it to a larger amp (my Spider Line 6 60watt amp) it won’t play through that….any ideas? Could I have wired it incorrectly from the speaker to the output jack?
My next toy was a children’s keyboard. I found one bend for it (in which I connected two resistors and then threw an on/off mini toggle switch onto). It makes the sound really distorted. On certain settings, once a key is pressed it’ll go on forever and with the distortion turned on, it really sounds drony.
Posted Image
I need to paint this one (or parts of it) and put an output jack on it. I may still fiddle with it for a day or two and see if I can’t get any more bends out of it or I may save it until after my next gig on Wednesday…
Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page)
stolenfat
PostPosted: Sat Jun 14, 2008 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
did you ground the output jack correctly?
Maybe it needs a preamp cause of a quiet signal? Try some out of disto pedal or something in a chain before the amp and see if it works.
Also, sometimes i've found theres often a connection which will boost the volume output, maybe you just need to find this connection which might increase the output level enough that you wouldnt need a preamp.
Not exactly sure if this is your problem but maybe it will help.
imaguitargod
PostPosted: Sat Jun 14, 2008 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a mock up of how I wired it, "Please excuse the crudity of this model, I didn't have time to build it to scale or to paint it."
Posted Image
The signle isn't quite, I do get a buzzing sound even when the unit is sitting idle (when plugged directly into the amp). I just tried the distortion pedles like you mentioned....it did amplify it slightly. I ran it through a distortion pedel and then a Wah pedel and I coul bearly hear it in the amp.
That's actually one of the first things I tried. Smile
stolenfat
PostPosted: Sun Jun 15, 2008 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmmm.... perhaps try bypassing the speaker all together?
I dont know exactly, but maybe extra power that could be used to boost the signal is being sucked up by powering the speaker....
Or, forget about the line out, leave the speaker there and try a peizo contact mic. Or a regular mic just next to the speaker.
You could always try searching for a small peramp circuit schematic and install it into the toy... but that may be a bit above your head (its above mine), and might require a bunch of extra non bending electronic work to get it working. But you never know, after some research it might seem like just the thing for you.
You do have a surprising problem though, it seems odd to me that a line out wouldnt work even after trying to preamp it. Maybe, try a different quarter inch jack? maybe its broken some how?
