Plasticman
Posted: Wed Apr 09, 2008 5:34 am Post subject:
Directories in ChucK |
When using Machine.add(), does it use the chuck file's parent directory, or the binary's? I tried to launch a file in a subdirectory with the code below, and the VM reported that the file did not exist.
| Code: | | Machine.add("./Modules/ModManager.ck"); |
edit: Could it be because I'm running Windows? The /example/shred/machine.ck example didn't work either. |
Posted: Wed Apr 09, 2008 6:54 am Post subject:
Actually, ChucK uses a path relative to the directory from which it was called. That may be the location of the executable, but likely it isn't as likely you put the executable in your path (copying it to /windows/system32/ will do).
If this is a problem you can use the full path in the file-name like;
Machine.add( "d:/chuck/myfiles/drums/snare.ck" );
I recommend using relative paths so you can easily move and distribute your code but this may not always be convenient.
Note that the MiniAudicle has a setting in it's menu to indicate the directory to work from, since it's a graphical application it's location in the directory tree isn't very meaningful most of the time.
Hope that helps. _________________ Kassen |
Inventor
Audio files: 270
Posted: Wed Apr 09, 2008 6:56 am Post subject:
Hmmm, I would try:
| Code: | | Machine.add("Modules/ModManager.ck"); |
leaving off the "./" at the beginning. Though I really don't know if that would work. ChucK itself should use the directory from which you launched it, and the miniAudicle has a place in the preferences where you can specify the directory. If the above suggestion doesn't work, try looking at this and other path examples in the docs. Good luck. _________________ "Let's make noise for peace." - Kijjaz |
Plasticman
Posted: Wed Apr 09, 2008 11:34 am Post subject:
| I was trying to run it from miniAudicle, once I used the command line it worked fine. Thanks! |
Posted: Wed Apr 09, 2008 11:42 am Post subject:
In that case you may want to check the MIni's settings for the starting directory. I think it's in the last tab of the settings. _________________ Kassen |
kijjaz
Joined: Sep 20, 2004 Posts: 765 Location: bangkok, thailand
Posted: Wed Apr 09, 2008 11:49 am Post subject:
| or do we need to replace / with \ on windows? |
Plasticman
Posted: Wed Apr 09, 2008 11:50 am Post subject:
| No, ChucK reads \ as an escape character. |
