Joined: Jan 22, 2008 Posts: 19 Location: Massachusetts
Posted: Thu Mar 27, 2008 6:49 pm Post subject:
What is the Frequency range of the Nord 2X- in Hz? Subject description: Need to know what amplifier to use.
Hello, I need to know what the frequency range of the Nord lead 2x is.
Audio files: 123
G2 patch files: 12
Posted: Sun Apr 06, 2008 7:45 am Post subject:
This is what can be found using the keyboard...
Attached are three *.wav files (zipped), the first two (a+b) make steps as large as an octave, the third one shows the usability of top of the range.
The test was made using Osc2, set in Saw wave form, because Osc1 only reacts to the keyboard.
The results are compared to the NordModularG2X, using my ears, which aren't the best to be found, btw. You can always try to find out the results using your own ears.
Higher notes are audible, but a lot of strange things happen. I'm not the expert on these things, maybe Jan can explain something here (aliasing?).
In notes the NordLead2 has a range of 0.375 Hz to 7 kHz, which doesn't mean there aren't any higher frequencies in the sound, but I can't detect it...
