28 Pin Conversion PCB question ?
Page 1 of 1 [4 Posts]
snufkin
PostPosted: Thu Mar 20, 2008 2:31 pm    Post subject:  28 Pin Conversion PCB question ? Reply with quote  Mark this post and the followings unread
is the 28 Pin Conversion PCB from blacet for the skinny sn chip worth it ?
i mean is it an actual socket from big to small or is it a board you have to solder the sn chip to ?
thanks
Audio files: 25
PostPosted: Fri Mar 21, 2008 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it worth it? Sure, the $4.50 asking price is actually a good one for an adapter board. Rather a cheap price to get your project off the ground also Very Happy
You will need to solder the skinny chip onto the board. The picture does not show any "pins" that solder to the outer edges so you may want to ask if Blacet supplies those. If not, you will have to hunt those down inj order to mount this onto your PCB ....
I don't know what your intention is but if it's to use a skinny SN76477 CSG with an SN Voice, the board will accommodate it already without any adapter. I believe this to be true also for the Thomas Henry Super controller board that Fonik had sold for a while.
Bill
 Filesize:  5.26 KB
 Viewed:  7702 Time(s)
snufkin
PostPosted: Fri Mar 21, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh cool
sorry Bill i hand not hunted down that picture
i was dreaming it was a socket that soldered to the larger pads on the sn voice board but could plug the skinny chip right in to Laughing
i guess ill just use a skinny dip socket
thanks for the info and thanks for the sn voice board i'm nearly done and thinking about getting a second
im making a small synth (space restrictions) maybe ill make it a duo voice !
Chris
Audio files: 25
PostPosted: Fri Mar 21, 2008 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, no problem !!!!! At least things are clarified for you, thats what matters Wink
Bill
PS: I will have about 100 of these boards in stock so they will be around for a bit ....... Very Happy
