 Forum index » Instruments and Equipment » Reaktor
Need a little help with my Midi-Stepsequencer
Page 1 of 1 [5 Posts]
m:o
PostPosted: Thu Mar 06, 2008 6:46 pm    Post subject: Need a little help with my Midi-Stepsequencer Reply with quote  Mark this post and the followings unread
i've built a simple midi sequencer in Reaktor for controlling my Nord Modular G1. Basically it consists of Trigger Steps, Volume, Pitch, and 3 CC parameters. But my problems comes here:
The pitch/note values are sent permanentely, regardless if a note is triggered or not. That means if i record the output of the sequencer, every adjusted Pitch/note value gets recorded over the whole time.
WHAT I WANT is that a note value is sent ONLY on Note trigger. So, something that will open/close the output of the pitch/note value according to the trigger signal.
Anyone can help me please ?
 Filesize:  86.78 KB
 Viewed:  934 Time(s)
m:o
PostPosted: Fri Mar 07, 2008 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
here's the .ens file if someone would take a view on this...
suggestions please
MIDI SEQUENCER .ens
 Filename:  MIDI SEQUENCER .ens
 Filesize:  171.54 KB
 Downloaded:  929 Time(s)
Chet
G2 patch files: 35
PostPosted: Fri Mar 07, 2008 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks like a cool sequencer. I'll take a look at it this weekend, but I have to warn you that I'm pretty inexperienced myself with MIDI generation in Reaktor.
ReaktorFreak
PostPosted: Mon Mar 10, 2008 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a trick that can be done, you can connect the pitch/note knobs to the value input of an (Event Processing->)Value module, then use Note Trigger as a trigger source for the same Value module. This will meet your expectation i guess, as the pitch/note value will only be triggered if there's a note trigger signal coming.
Chet
G2 patch files: 35
PostPosted: Mon Mar 10, 2008 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry, but I was unable to access electro-music.com from my home this weekend. It's a problem that comes and goes. I'll download the file now and work with it tonight.
