NordLead Bank Select in Cubase Studio 4
Page 1 of 1 [4 Posts]
one
PostPosted: Sat Mar 01, 2008 5:18 pm    Post subject:
Subject description: Clavia NL3 Bank Select
Hi, I'm trying to use the Bank Select on my Clavia NL3 (use a PC ).
But in the manual it say that I have to use MIDI Controller 32, I Can`t find the 32 in the Midi device manager. So I must do something Wrong Rolling Eyes
Can you help me? I`m using Cubase Studio 4
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 01, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I don't know much about CuBase 4 (still using version 1.1), but mostly it's called Program Change.
Be sure there is no Midi Filter (SysEx) active.
Make a Bank Change and a Program Change after each other. Cubase has to send these two messages, otherwise the synth won't do anything.
Just in case... Set the Global Midi Channel to a higher number then the ones you use for Midi in each Slot, so when A to D are set to 7 to 10, use 11 or higher (until 16)
Wout
one
PostPosted: Sat Mar 01, 2008 8:46 pm    Post subject: Thanks Reply with quote  Mark this post and the followings unread
Thanks for all the help! Very Happy
it whas so many combos in the Midi devise manager so I posted a new topic in hop that there are others that have Cubase Studio 4, and can help me
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 02, 2008 4:26 am    Post subject: Post original made by 'one'
Subject description: [moderator]
This post was made by one in another thread:
one wrote:
Hi, I'm trying to use the Bank Select on my Clavia NL (use a PC ).
