Nord Rack 2 Pitch Bend Problem
Page 1 of 1 [22 Posts]
mcpepe
PostPosted: Fri Jan 04, 2008 5:19 pm    Post subject: Nord Rack 2 Pitch Bend Problem
Subject description: It does not receive any MW or PB midi messages.
I have purchased a second hand Nord Rack 2. The OS Version is 1,06.
The Nord responds perfectly well to the notes i play from my midi keyboards, BUT doesn't respond to the mod wheel or the pitch bend at all. I have tried with 2 diferents keyboards (Remote 37SL and Yamaha SY77) with no success.
It is posiblle that the Nord Rack 2 is broken and doesn't receive pitch wheel and mw messages?
Thanks for the help.
Former site admin
Audio files: 353
PostPosted: Fri Jan 04, 2008 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know much about the Nord Leads, but it seems unlikely that it's broken in a way that would filter out pitch bend messages only. More likely it's a setting somewhere that's wrong. Probably when Wout tunes in here he'll know Very Happy
welcome BTW.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Good morning Smile
When a Rack is booting, it searches for the Keyboard, the PitchStick and the ModWheel. If it doesn't find these, the synth 'knows' it's a rack version. Broken or not, a rack is a rack and will stay a rack.
If you are able to connect a control pedal to the control input and [Shift + 7 times Special > E.of] is set, the pedal has the same function as the ModWheel. Try if the data works... Let us know.
Another thing can be, but I don't know 'why'... The former owner could DIY modified the connections inside. I know, it's a weird thought...
Wout
mcpepe
PostPosted: Sat Jan 05, 2008 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the answers.
I have connected a expression pedal in the control pedal input and it works correctlly. The expression pedal does the same function as what the mw should do. Perfect. The Shift+Special was in E.Of position.
BUT playing from a keyboard, the mw and pitch bend doesnt work.
I have done a few more experiments with a sequencer (Logic Cool. I play and record a track with notes, pitch bend, mw, expression pedal, program changes and moving the knobs of the N2r. Everything is recorded perfectly well. But when I reproduce the track (The N2r then receives the data from the physical midi input) only the notes and program changes worked well. It seems that the problem is that the physcal midi input only receives midi notes and program changes, and filters out everything else.
Looking at the Shift+Prog.Ctrl menu, the 3 parameters are "on".(P.on, C.on, A.on)
I am starting to think that the N2r is broken.
Thanks again.
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Again, sorry Very Happy , it's highly unlikely that it's broken in a way that selectively filters out pitch bend messages. This is because the incoming MIDI is a digital signal going into a digital circuit directly where the tones are computed, remember this synth really is a computer. So either all or no MIDI should be working. For the same reason it is also highly unlikely that someone moded the synth to filter out pitch bend messages.
I had a look at the manual, pitch bend reception over MIDI is implemented according to the MIDI implementation chart. Version 1.06 is the most recent software BTW.
It looks most like either the pitch bend messages do not reach the synth at all or that the pitch bend range is set to +/- 1 semitone maybe (in the system menu).
mcpepe
PostPosted: Sat Jan 05, 2008 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
The N2r is with the Pitch Bend Range set to "br2" in the system menu.
Remember that i have discovered that (with my sequencer experiment) it doesnt receive pitch messages, but also doesnt receive aftertouch, mod wheel, and all the CCs for controlling frecuency, resonance, attack, etc... It only accepts midi notes and program changes.
When the N2r is powered on it says "1,06" and nr2. It is in perfect condition, no scratches, knobs and buttons perfect, almost new. This is so strange....
I have contacted the previous owner and he says me that it worked well for him, but he doesnt used a keyboard, he used a sequencer to play the n2r.
This was a gift for "reyes magos" (like Santa Claus here in Spain), am I feel a lot sad.
Thanks a lot for helping.
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you try higher values?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Somewhere in the Midi 'line' these data are filtered out and, as Jan already wrote, highly unlikely in the NR2. Please can you describe your set up, like Midi interfaces etc?
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW has Logic (I never worked with it) a Midi Filter set up? If so, have you checked this? Important when you use a Midi Through option.
Have tried to connect the controller keyboard Midi Out directly into the Midi In of the NR2? (I assume both keyboards send out the desired data in the same Midi Impelmentation values...) You can also try Midi Global Channel on the NR2...
Wout
mcpepe
PostPosted: Sat Jan 05, 2008 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I have tried a few different setups, always with the same results:
a) Yamaha SY77 Midi Out---->Nr2 Midi In (directly without passing through computer)
b)Novation Remote 37 SL Midi Out----->Nr2 Midi In. (directly without passing through computer)
c)Logic 8 sequencer with midi data (notes, aftertouch, pitch bend, CCs,....I can see all this midi data in Logic without no doubt)--->RME FireFace400 Midi Out----->Nr2 Midi In.
In Logic, I am not filtering out these midi data. In fact i can see them in the screen.
Always the same results: Receive midi notes and program changes, but no pitch bend, mw, at or CCs.
I have tried with different values of pitch bend range (i.e: br9)
In menu Shift+Midi i have channel 1 for the slot A, ch2 for slotB, ch3 for slotC, ch4 for slotD. Global channel is set to 1 "G.1"
All keyboards (SY77 and Remote3SL) transmit in channel 1.
I am not new to MIDI, nor rack synths. I have played synths from 1989.
Thanks.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
mcpepe wrote:
... In Logic, I am not filtering out these midi data. In fact i can see them in the screen.
Always the same results: Receive midi notes and program changes, but no pitch bend, mw, at or CCs. ...
Seeing the data on screen means it's coming in and recorded, but it doesn't mean it's coming out too... Can you record just one short note in Logic and have you the ability to monitor if there's any Midi data on the NR2 Midi Input? Some LED...
After recording the short note, wait for about ten seconds and start to record some movements of the ModWheel. If it is there and the NR2 doesn't react at all, then it is a mystery...
I use a very old version of CuBase, which has a Midi Filter like the attached picture. Maybe there is something like that in Logic too?
I assume the Yamaha ModWheel is sending on CC#01. Otherwise it looks strange to me Smile
I can't believe a part of the software is broken...
Wout
 Filesize:  86.68 KB
 Viewed:  18547 Time(s)
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
didn't we we see issues with that before, I mean when the global channel was the same as one of the slot channels? Wout??
mcpepe
PostPosted: Sat Jan 05, 2008 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
NOW IT WORKS!
The problem was, like Blue Hell was saying, that the Global channel was the same as the Slot A. I have changed the Global channel to 5 and the pitch bend and mw are working ok now! The CCs, aftertouch, etc... are working ok now too!.
THANKS a lot for the help. I was going to discuss with the buyer...
Did I say Thanks! Very Happy
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
Hope you'll have fun now with your new synth Very Happy
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, as it appeared to be the issue there too. I still don't get it. Mostly I don't even think about Global Midi Channels, but it had something to do with Program Change and Performances, that other Thread...
Maybe a little FAQ paper to write, sometimes?
Just a rule here: If Midi doesn't work, change the Global Channel...
And yes, you said thank you Smile Glad to be at help.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
You mean 'seller'? The one who sold the present to the one who gave it to you. Maybe the seller has to thank Jan Very Happy
I just wonder why it worked in his studio then... scratch
Wout
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a perfectly logical reason for this Laughing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2008 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe... Never used the synth, so at last he sold it?
Wout
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope.
mcpepe
PostPosted: Sat Jan 05, 2008 4:52 pm    Post subject:   Reply with quote  Mark this post and the followings unread
I bought the Nr2 from a guy at a internet forum. I have not ever seen him.
When i first received the N2r, I plugged the Remote 37SL Midi Out to the Midi In of the N2r, but i heard no sound. My Remote 37SL was transmiting in channel 1, and the N2r was set to SlotA midi channel 5. The Global Channel was channel 1. If I simply would put my keyboard to transmit in channel 5, there would not be any problem. (I think thats what the seller did). But what I did was to assign the channel 1 to the SlotA (the same of global channel1) and it didnt work...
I was thinking the seller was a bad guy, but i was wrong. I finally have a working N2r, in almost perfect condition. Very Happy
To tell the whole story: I was dreaming of buying a new Nord Wave, but I have never tryed a Clavia synth, so I thinked why not buy a 2nd hand Nord to play with it before spending so much cash in a new Wave? I can play a few months with it and if I really like it, sell it (i will not loose too much money) and spend the big money in the Wave.
So little time playing with the N2r but I like the sounds, it seems very expressive to me, with great sensivity to the touch of the keys. I hope I will spend good times with it!
Former site admin
Audio files: 353
PostPosted: Sat Jan 05, 2008 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
See, this makes perfect sense Laughing
On evaluating the wave please don't listen to Clavia's demos too often, I heard much nicer ones elsewhere.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jan 06, 2008 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Indeed, it makes sense. Midi Channel 5 was his lead channel in his studio. I think people should make a rule out of it: When selling something, always deliver in 'Factory' settings...
The other Global issue was the NL wouldn't react to Midi CC #7 during playing a sequencer.
Wout
