 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Help with clock generator
Page 1 of 1 [4 Posts]
AntonyPath25
PostPosted: Fri Nov 30, 2007 1:05 am    Post subject: Help with clock generator Reply with quote  Mark this post and the followings unread
Hi guys i have this patch & i want to connect the clock gener. so every time my lfo to begins from the some point !
i know its easy but my english doesnt help Sad
fullon clock question.pch2
Clock Generator
 Filename:  fullon clock question.pch2
 Filesize:  1.77 KB
 Downloaded:  2166 Time(s)
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Fri Nov 30, 2007 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
The LFOB and SHPA modules have (Rst) inputs, which allow the waves to be set to a starting point.
If you want the LFO reset at the start of each bar, use the [Sync] output. If you just need it set once at the start, use the [Clk Active] output.
You can set the point the LFO starts at using the Phase knob.
AntonyPath25
PostPosted: Fri Dec 07, 2007 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
its easy an example ??? i make the conection but it doesnt work it doesnt begin from the some point Confused
Former site admin
Audio files: 353
PostPosted: Fri Dec 07, 2007 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like this maybe? I'm not sure I understand what you want exactly Very Happy
fullon_clock_question_mod.pch2
 Filename:  fullon_clock_question_mod.pch2
 Filesize:  1.88 KB
 Downloaded:  3187 Time(s)
