Bug: is it ChucK or me?
Page 1 of 1 [6 Posts]
Inventor
Audio files: 270
PostPosted: Fri Oct 26, 2007 12:30 am    Post subject: Bug: is it ChucK or me?
Subject description: possible bug in ChucK
I have been staring at this evil bug for two hours now, would someone mind taking a look at it? I think it might be a ChucK bug because it's really simple and I just cannot figure it out. fsamples[f1] goes out of range at 8 even though it is declared to be fsamples[128]. I tried changing variable names, looking elsewhere in the file, and using constants instead of variable names with no success. I isolated it with the print statement <<< t, f1 >>>; which only counts to 8 before it crashes. I am running the command line code of chuck version: 1.2.1.0 (dracula) on Mac OS X. Thanks in advance.
CrystalFFT1.ck
Contains a bug! Does not werk!
 Filename:  CrystalFFT1.ck
 Filesize:  3.28 KB
 Downloaded:  344 Time(s)
PostPosted: Fri Oct 26, 2007 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Very odd, I suspected it might be a different array that goes out of bound but I can't find any arrays of size 8 or smaller there? Arrays going out of bound are most often little mistakes in the ChucK program, the hard part is that ChucK doesn't tell you the *name* of the array that goes out of bound when it quits.
If you're sure that's the array you should mail Ge himself, he knows everything Smile.
Inventor
Audio files: 270
PostPosted: Sat Oct 27, 2007 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I am sure that is the array because when I put 0 into the index of fsamples[] it runs, but if i put f1 in it, it crashes right after printing that f1 is 8. I emailed Ge, we will see what happens. The more I think about it, the more I think its a ChucK bug.
Inventor
Audio files: 270
PostPosted: Sat Oct 27, 2007 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I found the bug! I had used .cvals() instead of .cval() to access the FFT samples. I changed it to fval() which is what I was really looking for anyway, the magnitude, and it works great now! Anyway it gave me a good reason to email Ge and send him my compliments! Cheers.
PostPosted: Sun Oct 28, 2007 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, my bad. I was torn between arrays going out of bound being the mistake I myself make most often and it generally being good policy to doubt ChucK especially with newer features.
ge
PostPosted: Sun Oct 28, 2007 4:15 pm    Post subject: ChucK is at fault, I think Reply with quote  Mark this post and the followings unread
Hi! In tracking things down, the problem was that upchuck() wasn't working when now is exactly 0. This has been fixed. .fvals() and .fval() access the same array, and shouldn't behave differently. If they are, then there may be another bug! Heh.
I reiterate what Kassen said: when things get really weird, doubt chuck (because it usually is due to chuck)!
